I've had this problem before. I forget how I fixed it. I think I deleted all images and then re-inserted them a different way.
I cheated and made it very small!
1
I've just tested a print with this setting on (brigde settings) but the result was....spaghetti
I printed this : https://www.youmagine.com/designs/quick-temperature-fillament-test in greentec, with basicly default PLA settings (210°c)
Why are default feedrate set to 15mm/s ? Its way too slow, the string have plenty of time to sag, it doesnt help when flow is reduced to 75% either...
I edited settings with 60mm/s feedrate and flow back to 100% and got very nice bridging
Hi @catohagen, thanks for the feedback. Well, all I can say with regard to the default settings is YMMV. They work for me just fine but I don't for one moment expect them to be optimal for other people. So, you have to experiment and find what works best for you. You can then share that info with others and when enough people have tried it out and got good results we will have an idea what are the default values that are most likely to be successful.
Edited by burtoogleLast week I designed a little test model to demonstrate the limitations of an FDM-printer to people who have no experience with it, but who want something designed and 3D-printed. Purpose was to show big overhangs and tiny extensions that get not enough cooling (the little cones at the top). I also used it to experiment with temperature and speed settings, for best results.
But the model might also be usefull for this new bridging function. So, feel free to experiment with it. Size is fairly small: ca. 40mm x 30mm x 30mm, about 1.5h printing time at 50mm/s.
The item at the back is a real bridge, with at one side a small horizontal overhanging plate, and at the other side a 45° overhang.
The bow at the front only has support on one side. So the goal here is to find settings that do produce the minimum amount of spaghetti, and the minimum of curling upwards while printing.
STL-file: overhangtest3d.stl
Edited by geert_2
3
Torture print... I like! ^^
Except I can't: 'You cannot add more reactions today' ?
10 minutes ago, Brulti said:Torture print... I like! ^^
Hi Brulti, did the forum software tell you this? There are limitations to new users, to protect us from being spammed into oblivion but you should be in the clear. Could you try again, and if you can not, could you send me a DM? This should still work.
@Brulti is too expressive....
DM sent without a hitch, still unable to react to any message.
Hi @geert_2, thanks for the torture model. However, I cannot see how any FDM printer would be able to print that satisfactorily without the use of support. Bridging is only appropriate when there are multiple pillars that the bridge can be spanned across. Bridging cannot help when only one side of the area has support under it.
Ah, it is set to a max of 10 reactions/likes a day. I guess I didn't expect us to be such a likeable bunch of people when I set it up initially
I'll change it to unlimited, so you should be able to express your appreciation to your fellow forum members again!
Apologies for the inconvenience.
1
16 minutes ago, SandervG said:Ah, it is set to a max of 10 reactions/likes a day. I guess I didn't expect us to be such a likeable bunch of people when I set it up initially
We're all very likeable here! Thanks for the quick reaction!
1
1 minute ago, smartavionics said:...
Yes, I understand. But a lot of other people don't know.
So that is why I needed a demo-model to show them the effect with and without supports.
But for such a single-sided overhang like the bow above, if printed without supports, I have been wondering if the results would be better (=less spaghetti, but of course still some spaghetti) when the first layer is printed length-wise? Or if it is printed transversal, line by line, maybe with a reduced line-spacing (=thus with some overlapping), so that each line still glues a bit to the previous line? Very hard to predict.
In real life, printing small horizontal overhangs might be usefull for an architect who wants to print a house model, and the roof is overhanging a little bit from the walls. Or if you want to print a vertical pipe with a little flange.
For my real designs, usually I include the supports in the CAD design itself, like this (=the 2 purple items with ribs), for printing on my UM2. The hollow pink block is a dummy to provide enough cooling while printing the tiny top area of the model.
Yes, @geert_2, I agree with all that you say.
One other thing that I was discussing with a friend recently was the idea of using a bridge as support below the real bridge which is printed just like it would be done above normal support. Once the print is finished the bridge-support is removed to leave a very good quality bridge on the model. That could save a lot of time and support material.
1 hour ago, smartavionics said:Yes, @geert_2, I agree with all that you say.
Yes that seems like an excellent idea, if it can be done without too much damage to the side walls (in single nozzle printers with only one material).
The concept might also work for small overhangs like roofs, if you would build a sort of triangular support that is only sticking lightly to the side walls, just enough to keep the roof in place, but still easy to remove.
I have quickly modeled such a thing in DesignSpark Mechanical. It's a very crude model, just to try the concept. The supports (yellow and red) are totally separated from the model (cyan). For adhesion, they would rely on the spaghetti and nozzle leaking that is produced in the first layers of these supports. Currently the horizontal gap is 0.5mm, and the vertical gap between the ribs and roof is 0.3mm, but these might need adjustment. I am curious if it is going to work? Next week I will print it (I am not here tomorrow).
Edit: dimensions: center overhang = 30mm, side overhangs = 5mm, width = 15mm. Little ribs on supports = 0.5mm wide, with gaps of 1.0mm in-between.
Edited by geert_2
Hi @geert_2, I made a test model to try out the idea of "flying support", i.e. printing support on top of a bridge. It worked very well and I think could be a useful technique in those situations where you need support but it's either a long way down to the bed or you really don't want to print support on top of the model that is below. Here's a picture of my test piece. You can see the bridge (which is cut off and thrown away along with the flying support) is only one layer thick at its first layer. Sure, it does leave a visible mark on the vertical pillars when it is cut away but it's not horrendous.
BTW - the 3.3 beta bridge code doesn't have a few changes that stop bridges being printed over support so if you try to recreate this using 3.3 beta you will find that it will print the skin layers above the support as bridge layers which isn't what one would want. I have made the required changes but they haven't been merged into the Cura release branches yet.
Update: You don't even need to make the first bridge layer the whole width, so in my test model I reduced the first layer to two 3mm wide "spars" that span the gap between the pillars. Certainly with PLA, the sheer strength is such that you don't need very much width to support the bridge.
Edited by burtoogle
Oh yes, @ahoeben, I used the support blocker to remove the support between the build plate and the bridge in my example above. Thanks!
Edited by burtoogle-
1
Here the print results of my free hanging support tests shown above. (To avoid confusion, keep in mind that this is a manually created test model, not automatic support generation.)
The basic idea of a support bridge to support the real bridge works great. The underside of the real bridge is as good as it can get with a single nozzle printer (UM2). And the support is easy to remove. So I am definitely going to include this concept in my inventory of support methods. Thanks to smartavionics for the great idea.
But my model still needs refinements. The triangle support shapes do need modifying. This will take some trial and error. Now the edges curl up way too much at the outside (more than 1mm, at 0.1mm layer height). Then the nozzle crashes into these curls violently, and tends to knock the model off the build plate, or to separate the supports from the model. As you can see in the light green model (PLA, 210°C, 50mm/s). The dark green model survived, but was printed much slower (25mm/s), so the nozzle crashes were not as severe.
Also, for optimal stability the free hanging supports would need a few little strands to connect them to the main model. Relying on the spaghetti works well for the first layers, but after a couple of layers there is no more spaghetti. So there it needs a few connecting strands. Using strands in well defined places might also reduce the amount of damage to the side walls of the real model. This also will take some testing.
But the basic concept definitely can be used for printing small overhanging roofs and flanges.
1
I have wondered if it would be beneficial on bottom bridge layers to lower Z slightly in the first 1/2 -2/3 of the bridge span while stringing across, then in the last portion return to the normal layer height. The purpose would be to fight the natural sagging that occurs while the line is still flexible, then connect it to the support at the other side. Also, I have seen where when printing adjacent bridge lines ( especially bottom bridge layer) where the nozzle dissturbs the previous line and breaks it, sticking to the nozzle. Lifting slightly in mid bridge would defeat that I think.
The Z motion mihht likely be a parabola relative to the bridge length...
Hi @mastory, in my testing with PLA, I have found that with suitable speed/flow/fan settings, the first layer strands do not sag on small to medium length bridges (say up to 50mm). Maybe for longer bridges or difficult materials the parabola would be worth trying. It would be straightforward to implement in Cura.
SandervG 1,521
My first attempt of 'backspace' didn't work, I'm sure you tried it as well
Let me take a deeper look.
