I had the same issue again - with latest firmware.
My print kept pausing saying I was out of filament (I wasn't) and eventually (because it kept working) I turned off the flow sensor... Many hours later I ended up with this - guess it did stop flowing at some point, but I wish that sensor was more reliable 😞
Top Posters In This Topic
14
7
7
6
Popular Days
Nov 12
11
Aug 15
6
Jul 1
6
Jan 30
5
aag 14 posts
kmanstudios 7 posts
Shadowman 7 posts
robobartz 6 posts
Popular Days
Nov 12 2018
Aug 15 2018
Jul 1 2019
Jan 30 2019
Popular Posts
kmanstudios
I would not say always. Here would be the thought behind that. Find out what angle your printer can do without supports. For instance, this is a two colour print without supports.
blanerobinson
I have this same error coming up when I print with the more flexible filaments: PVA, PP, TPU. It was maddening until I dug into the hardware a bit. There was no tension on the feeder (the indicator wa
WesleyE
That does not look good. Can you check a few things to rule out some causes? Can you check if you're in the latest version of the firmware? We improved the end of filament detection a lot since the fi
Posted Images
Jdn 0
I have a New S5 on 5.1.8 20181207 printing ABS in Extruder 1 that gets the same error now. I just shut off flow control. I have PVA in extruder 2. but it is not selected for support.
Is this the latest firmware?
