There is a printer definition in the latest Cura for Mark2 variant, has anyone edited to create a DXU profile in Cura 4.3?
- 2 weeks later...
The DXU works with Cura 4.03 if choosing the Mark2, input your printer specific dimensions and filament, even the post processing file works, change the start- Goode to match the DXU profile we have in Cura 3.6 and that’s it..so far I have printed calibration cubes with dual color with no issues, have not printed a large model yet. Think it is promising
- 2 weeks later...
DXU and Cura 4.3 - changed the disallowed areas to match the DXU def.json file and the backplate image. Print area is now showing as the original DXU - without it the print area is minimal on the Mark2 def.json if choosing extruder 1 and 2
does anybody knows if other changes are needed?
1 hour ago, Garufa said:DXU and Cura 4.3 - changed the disallowed areas to match the DXU def.json file and the backplate image. Print area is now showing as the original DXU - without it the print area is minimal on the Mark2 def.json if choosing extruder 1 and 2
I haven't checked the new embedded Mark2 profile. You will also need to change platform shift and print area. I'm not sure if Mark2 has the material adhesion option enabled.
But for me the old DXU profile works directly with Cure 4.3, so I didn't find it necessary to do a new version. Did it not work for you?
On 10/29/2019 at 2:36 AM, luke199 said:Hey all,
What's the recommended general retraction length and maximum?
I use 6.5mm, 25mm/s, same as UM2+ default.
yyh1002, My bad, when migrating to version 4.0 all my settings became corrupted and could not make it work. I just tried with 4.3 again with your profile and works !!! - thank you.
Thanks yyh1002. I run some tests and between 2.70 and 3.50 @25mm/s is perfect depending on material
- 4 weeks later...
I ran into a problem. I have converted my UM2E over to 1.75mm and 4/2 bowden. The top of the one part is fitted to connect with a 6/3 bowden tube. I was able to use an existing PTFE connector I had and a coupler to mate with the top of the metal tube, however it does not match up with your design. I also switched over to a BMG feeder and it is all setup to use 4/2 bowden as well. Any chance you can sent me your housing front in a step or other cad file so I can modify it for my use?
Edited by ddt154- 1 month later...
Bonjour
puis cura version 4.4.1
quelle que soit l'extrudeuse que je choisis, c'est toujours extruder 1 qui imprime
pouvez-vous me fournir la définition et les fiches de ressources de l'extrudeuse
using the DXU cura v3.4 source file in nozzle it displays empty
merci
J'ai les fichiers que j'utilise
Edited by Anzen
comme je n'est pas de réponse
je doit modifier le gcode en rajoutant T1
;FLAVOR:Marlin
;TIME:1528
;Filament used: 0m, 0.580902m
;Layer height: 0.15
;MINX:104.25
;MINY:96.75
;MINZ:0.27
;MAXX:133.75
;MAXY:126.25
;MAXZ:19.92
;Generated with Cura_SteamEngine 4.4.1
T1
M82 ;absolute extrusion mode
;material_bed_temperature=60 material_print_temperature=215.0 material_print_temperature_layer_0=215.0
M190 S60
M104 T0 S175
M109 T1 S215.0
M104 T0 S200
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
M200 D0 T0 ;reset filament diameter
M200 D0 T1
G28 Z0; home all
G28 X0 Y0
G0 Z30 F2400 ;move the platform to 30mm
G92 E0
T1 ; move to the 2th head
G0 Z20 F2400
G92 E-7.0 ;prime distance
G1 E0 F45 ;purge nozzle
G1 E-5.1 F1500 ; retract
G1 X90 Z0.01 F5000 ; move away from the prime poop
G1 X50 F9000
G0 Z20 F2400
T0 ; move to the first head
M104 T1 S175
G0 Z20 F2400
M109 T1 S215.0
G92 E-7.0
G1 E-5.1 F1500
G1 X60 Z0.01 F5000 ; move away from the prime poop
G1 X20 F9000
G1 E0 F1500
M400 ;finish all moves
G92 E0
;end of startup sequence
G92 E0
T1
G92 E0
G1 F2100 E-5.5
;LAYER_COUNT:132
;LAYER:0
M107
M204 S375
M205 X17 Y17
G0 F2400 X108.876 Y96.761 Z0.27
M204 S250
M205 X10 Y10
- 4 weeks later...
On 1/19/2020 at 4:23 AM, Anzen said:Hello
then cura version 4.4.1
whatever extruder I choose, it is always extrude 1 which prints
can you provide me with the definition and resource sheets of the extruder
thank you
I have the files I use
Hi Anzen,
Sorry for the late reply.
There is a critical bug for Cura 4.4.1, which is exactly what you found. It cannot generate correct tool number in start code for dual prints.
They fixed the bug in 4.5 beta. You can use 4.5 beta now. But I think the first layer path of 4.3-4.5 is not as clean as 4.2.1.
I uploaded new profile for Cura 4.5 to Github. And also an updated version of firmware.
This new firmware will prevent any tool change when head position is unknown. It avoids the problem of bad start code movement caused by the first "T0" or "T1" generated by Cura which makes the printer to think it's holding a wrong head.
It works together with a new start code that automatically select and purge the nozzle used in a print.
The machine "DXU" should be used for single nozzle print, either left or right nozzle.
The machine "DXU Dual" should be used for dual nozzle print. The difference between the two is start code.
1
- 3 weeks later...
Hi there,
I decided to start building the DXU upgrade for my UM2+ ordered al the hardware parts and polycaronate for printing all the parts. The only doubt I had was that the 35w heater would be on the light side, so I replaced that with a 40W heater set. It might be too much as well resulting in a less sable temperature, but we will see. As soon as all is finished Ill share the results. Furthermore I managed to get most of the parts directly from Aliexpress and some were ordered via Superuser (good taobaoagent) when there was a substantial price difference for the same quality. the price for all was around 110 euro's.
Best,
Crispijn
Edited by cvansas
BOM was incorrect and deleted to prevent confusion
the previous BOM was the unsaved original. Now the edited version with all the parts from 2 aliexpress suppliers: SANBrother and bolts from Nindejin. Please note the following:
- as earlier mentioned the Hotend kit from SANBrother is slightly different and requires some adjustment of the original DXU design.
- Some parts are available on Ali but much more expensive. Primarily the Fans, PI insulator, extruder motor.
Hi there,
I decided to start building the DXU upgrade for my UM2+, however I noticed that the hotend kit found on taobao is not available at this moment and that the alternative aliexpress variant would differ in size. Therefore I was wondering whether it would be possible to acquire the original design file (fusion 360?) in order to make the necessary modifications to fit the SANbrother hotend. Also I would like to slightly improve the design with snap fit casing, countersunk screws and slightly bigger dimension of the fan part attachment.
- 2 weeks later...
On 3/12/2020 at 10:10 AM, cvansas said:Therefore I was wondering whether it would be possible to acquire the original design file (fusion 360?) in order to make the necessary modifications to fit the SANbrother hotend.
I've just uploaded the step file, something to play with for anyone interested during the crisis .
1
- 4 weeks later...
What Modifications is needed to use the SANbrother Hotend?
- 3 weeks later...
hello I would like to make this change to my um 2+ ext, I would like a couple of information, the components can be sampled in abs and possibly know layer height and filling density, in addition I would like to know if it is possible to keep an original olsen as a second extruder from 2.8mm instead of applying 1.75mm model, thanks
- 2 weeks later...
the 3510 12v fans are nowhere to be found, they cost more than the printer, do you have any idea where to find them or if it is possible to put 5v fans?
Just go on Aliexpress maybe they have blower fans
- 2 weeks later...
DXU profiles are now included in Cura 4.6 by default.
The profiles in 4.6 is pretty much the same as the one on Github for 4.5.
One for single nozzle print and one for dual nozzle print.
The postprocessing script is no longer needed.
1
yyh1002 60
Not really. There needs to be about 1-2mm spacing between the top of heat block and hex flange on heat break. The block is loose before install the nozzle, and you can turn it to proper direction so it doesn't touch anything. When nozzle comes in, it will lock everything tight.
