Is this mod still only for 1.75 filament?
2 hours ago, danielkrice said:Is this mod still only for 1.75 filament?
I went looking for a version of the hardware for 2.85 mm filament and had trouble. I'm going to order the 1.75 mm hardware on ali and see what I can make or modify for 2.85 mm filament.
bob-hepple 59
Really like the look of this design which Firmware are you using is this custom,, also what slicer I use S3D and find the Mark 2 a little awkward to use with it... VERY Good work though highly impressive.
- 2 weeks later...
On 4/7/2019 at 10:55 AM, danielkrice said:Is this mod still only for 1.75 filament?
On 4/7/2019 at 1:19 PM, burdickjp said:I went looking for a version of the hardware for 2.85 mm filament and had trouble. I'm going to order the 1.75 mm hardware on ali and see what I can make or modify for 2.85 mm filament.
- 2 weeks later...
On 4/7/2019 at 12:19 PM, burdickjp said:I went looking for a version of the hardware for 2.85 mm filament and had trouble. I'm going to order the 1.75 mm hardware on ali and see what I can make or modify for 2.85 mm filament.
Any luck?
Hi, you could buy a "Ultimaker 3 printcore AA 0.4" for disassembling. Than you could use the 2.85mm parts an the Olson lock
ummmmmm not a bad idea but was hoping for a cheaper option...
My 1.75 mm parts are on the way from alibaba. I'll report back when I've had a chance to investigate them.
1
My parts came in. They look really good!
I'll take measurements, put together some solid models, and write up a description sometime this week.
Here's my first blog post about the hot ends:
https://burdickjp.gitlab.io/2019/05/14/dxu-1.html
Verdict: I think I've found an easy way to run 2.85 mm filament.
Edited by burdickjp
1
On 5/15/2019 at 9:39 AM, burdickjp said:Here's my first blog post about the hot ends:
When you buy on Taobao you have the option to buy PI rings so the tube is not in contact with the hot end
yyh1002 wrote:
I added a PI ring between the nozzle and PTFE tube for heat resistance, similar to the one by 3D Solex
Edited by GarufaTo quote text
- 2 weeks later...
On 4/8/2019 at 1:37 AM, bob-hepple said:Really like the look of this design which Firmware are you using is this custom,, also what slicer I use S3D and find the Mark 2 a little awkward to use with it... VERY Good work though highly impressive.
Thanks. Software side it works basically the same as Mark 2, hence similar CURA and E3D profiles.
On 5/15/2019 at 11:39 PM, burdickjp said:Here's my first blog post about the hot ends:
Nice post.
The 1.75 hotend runs with a custom 6.35 OD 2 ID PTFE bowden tube, sold by the same Taobao seller. The major advantage of this PTFE hotend is that there is pretty much no chance of nozzle jam or clog for PLA even with frequent long retractions. With the PI insulator ring applied, the PTFE last much longer and can also handle high temp materials. As for using E3D heatbreak, the current heatsink probably won't be able to cool it down properly because the surface area is much smaller.
You can consider trap a piece of 6.35 OD 3.2 ID or 5 OD 3 ID PTFE tube inside the heatsink. I think the 4*3 PTFE would deteriorate pretty quick due to thin wall thickness, and it is also too soft to hold up to the compression from filament. Making 1.75 and 2.85 hotend components swappable isn't all that necessary. You would need to make compromise on both sides to achieve that. I think it would be better to make two entire printheads with 12pin connector for quick swapping. That would be much less hustle, much more reliable and cost very little.
2
5 hours ago, yyh1002 said:The 1.75 hotend runs with a custom 6.35 OD 2 ID PTFE bowden tube, sold by the same Taobao seller. The major advantage of this PTFE hotend is that there is pretty much no chance of nozzle jam or clog for PLA even with frequent long retractions. With the PI insulator ring applied, the PTFE last much longer and can also handle high temp materials.As for using E3D heatbreak, the current heatsink probably won't be able to cool it down properly because the surface area is much smaller.
I'm not necessarily looking at being able to swap between 1.75 mm and 2.85 mm with the same hot end. I'm looking to use the same form factor for both. The same, or mechanically compatible, external dimensions.
1
- 2 weeks later...
Looking forward to a 2.85mm solution for this mod, as I simply don't like using 1.75 in a bowden setup. Cheers and great work.
On 6/6/2019 at 6:09 PM, artistebot said:Looking forward to a 2.85mm solution for this mod, as I simply don't like using 1.75 in a bowden setup. Cheers and great work.
I am, too!
It will be a short while as I am in the middle of a move. I've got some new ideas, but they're not mutually exclusive ideas.
I intend to test the hotends in my ultimaker as it is before changing to the DXU.
- 2 weeks later...
On 9/22/2018 at 5:41 PM, yyh1002 said:Hey guys,
I would like to share a lever action dual extrusion solution I came up with for Ultimaker 2+.
The approach is based on the great effort everyone put into Mark2 and Ultimaker 3.
The print head holds two hot ends, which are originally to be installed on standard UM2 head for 1.75 filament. The right nozzle move up and down for nozzle swapping.
This compact dual print head can achieve single extrusion print area of 220x223x205, and dual extrusion print area of 202x223x200.
Video clips:
Files and instructions available at:
https://github.com/yyh1002/DXU
Credits:
Lever lifting mechanism is inspired by Ultimaker 3.
The firmware is modified based on Mark2 version of Tinkergnome firmware by @tinkergnome.
CURA profiles are modified based on the Mark2 profiles by @tinkergnome and @foehnsturm. Used Mark2Tweaks plugin for CURA by Krys Lawrence.
is this upgrade also possible on the UM2?
Yes it is possible. You couls do it on UMO, UMO+, UM2.
I upgraded my UMO+ to UM2 DUAL+
http://www.jtronics.de/werkstatt/3d-drucker-ultimaker-umo-upgrade/
Next time I will upgrade it to DXU.
The printing results are the same like with my Ultimaker 3.
1
- 3 weeks later...
I cant seem to find the PI insulators on Ali express. I tried ordering from TaoBao but they held my order and never shipped it, they also kept my payment. So I bought what is on Ali and the Heat sink is different, although dimensionally the same, the fins are thinner and more of them. So the heat sink clamps in the files don't fit.
Hi all,
I just bought an Ultimaker 2+ Extended and since I have used a CR-10 for about 2 years I still have a lot of 1.75mm filament and the 1.75mm filament is highly available in my country, therfore I would like to convert the UM2+ to 1.75mm.
I would also like to try out dual extrusion and direct drive, and I found this thread, which seems to include the 1.75mm part and also the dual extrusion part. It also seems to do it for around the same price as it would cost to only do the 1.75mm conversion.
I have looked a lot into the BOM and the seller from Taobao's store and found that almost all that is needed is possible to buy from this seller. Are there any reasons why you choose not to do that? Bad quality or something like that?
Here is the list I have created:
Item | Amount | Price/Item | Total Price (RMB) | |
UM2 1.75 Hotend Kit (Heatsink, Bowden Coupler) | 2 | 35 | 70 | |
UM2 1.75 Hotend Heat Block | 2 | 25 | 50 | |
290°C High Temp Print Hotend Insulator 2*4*1 | 2 | 32 | 64 | |
UM2 Heater Cartridge | 2 | 55 | 110 | |
UM2 PT100 Sensor | 2 | 42 | 84 | |
2*6.35 PTFE Bowden Tube | 2 | 15 | 30 | |
6.35 Bowden Coupler | 2 | 1 | 2 | |
1.75 Filament Feeder | 2 | |||
NEMA17 42*48 Stepper Motor | 1 | 49 | 49 | |
3510 12v Blower Fan | 2 | |||
3010 5v Hotend Cooling Fan | 1 | 7.5 | 7.5 | |
Linear Bearing LM6LUU 6*12*35mm | 2 | 16 | 32 | |
Total: | 498.5 |
Can I still use the original feeder but with a 2*6 PTFE Bowden tube and then buy this extruder: https://item.taobao.com/item.htm?spm=a1z10.3-c.w4002-9900754940.72.2ada2d37ndiKyj&id=525270842166 and use a bowden tube made for 1.75mm or would that cause problems? Maybe it's better to buy two of the metal feeder? If so, I guess I only need two "normal" 1.75mm bowden tubes? The 2*4*1 insulator is out of stock right now, I guess 2*4*1.5 wont work, so I need to wait until it's back in stock before I can order anyway.
One of the reasons I would like to order everything or most of the stuff from the same seller is that we pay a fixed tax/package here, the other is to save on shipping, and also that I get all the items at the same time 🙂
- 2 weeks later...
Hi again,
It doesn't seems like it's possible to edit a post, so I have to create a new one.
I asked a chinese colleage to ask the seller about the 2*4*1 insulator, and the seller said that he will not restock it. Do someone know if it's possible to order it from somewhere else?
12 minutes ago, hakkattakk said:Hi again,
I asked the seller. PI insulator is still available. The stock from now on is 2*4*1.5, which also works with DXU.
1
I got it working with 2,85mm filament, i ordered 26mm Stainless Steel heat break with teflon PTFE tube for 3mm filament ( 26mm heatbreak withe PTFE on aliexpress ) ,
Teflon PTFE tube OD 4mm / ID 3mm on aliexpress
Have it working for a few weeks now without problems
1
50 minutes ago, klaasie said:I got it working with 2,85mm filament, i ordered 26mm Stainless Steel heat break with teflon PTFE tube for 3mm filament ( 26mm heatbreak withe PTFE on aliexpress ) ,
Why the heat break?
Top Posters In This Topic
44
14
14
10
Popular Days
Apr 3
8
Sep 13
6
Sep 23
5
Apr 7
5
yyh1002 44 posts
Garufa 14 posts
dadoblu_2000 14 posts
burdickjp 10 posts
Popular Days
Apr 3 2019
Sep 13 2020
Sep 23 2018
Apr 7 2019
Popular Posts
yyh1002
Hey guys, I would like to share a lever action dual extrusion solution I came up with for Ultimaker 2+. The approach is based on the great effort everyone put into Mark2 and Ultimaker
yyh1002
Some recent timelapse and photos of DXU.
Benleo888
Below the sample printing video with PLA+PVA after modification.
Posted Images
rajilpahuja 37
Well i had a small part to play in that..... cause they actually got me the parts from taobao 😉
