Old problem resurfacing?
I start 4.7, try to add a non network printer, cura crashes.?
Is it me?
Windows 10, Intel I5
Edited by Buj
missing info
- 2
Is it me?
Edited by Buj
There's a Bug when i choose Tevo T Pro. The bed are fliped.
18 hours ago, ahoeben said:PS: @fieldofview is @ahoeben on the forum.
Fixed that for you, I wasn't sure and thought I used FieldofView before in such context. Will keep it in mind.
that's nice but i cannot install on my Mac, because its refused because of safety problems.
Thanks for the update!
It didn't bring in my profiles and settings from 4.6, as (I think) previous updates did (I did click uninstall 4.6 and also allowed it to remove all my profiles, so it might be my own fault, I was too fast in clicking next,next, yes I guess - on the other hand I think I did it like this since before Cura 2 and usually worked). Might be beneficial to ask if the user wants to import their settings to the new version, rather than asking to delete them from the previous install (which I always do, as I don't want lingering folders of uninstalled programs). It wasn't clear to me that they wouldn't be imported if I chose to delete them.
I tried loading backups (old ones though, latest was from Oct 2019) and Cura crashed the first couple of tries when accepting to "close Cura now". After that I clicked No and closed Cura manually, which helped.
It will not load any profiles from gcodes made in 4.6, but this might be expected?
Cura 4.7 has a bug where if you choose the eSUN PLA+ material profile, all printing profiles disappear. If you choose a generic PLA material profile, the printing profiles come back.
If they disappear, how did you manage to choose the generic profile?
2 hours ago, Verne64 said:Thanks for the update!
I just installed 4.7, let it uninstall 4.6, but KEPT my profiles.
Cura 4.7 crashes every time I try to open an STL file. The program itself will run, but crashes if I try to open any STL I have tried. I get error logs as follows:
Traceback (most recent call last): File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\cura\CuraApplication.py", line 1060, in event File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\Qt\QtApplication.py", line 464, in event File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\Event.py", line 218, in call File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\Signal.py", line 332, in __performEmit File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\cura\CuraApplication.py", line 1820, in _readMeshFinished IndexError: list index out of range Thread 0x000032a8 (most recent call first): File "C:\Program Files\Ultimaker Cura 4.7\plugins\RemovableDriveOutputDevice\RemovableDrivePlugin.py", line 61 in _updateThread File "threading.py", line 862 in run File "threading.py", line 914 in _bootstrap_inner File "threading.py", line 882 in _bootstrap Thread 0x000051d4 (most recent call first): File "threading.py", line 297 in wait File "zeroconf\__init__.py", line 2117 in wait File "zeroconf\__init__.py", line 1434 in run File "threading.py", line 914 in _bootstrap_inner File "threading.py", line 882 in _bootstrap Thread 0x000031f8 (most recent call first): File "threading.py", line 297 in wait File "threading.py", line 549 in wait File "C:\Program Files\Ultimaker Cura 4.7\plugins\UM3NetworkPrinting\src\Network\ZeroConfClient.py", line 81 in _handleOnServiceChangedRequests File "threading.py", line 862 in run File "threading.py", line 914 in _bootstrap_inner File "threading.py", line 882 in _bootstrap Thread 0x00000c58 (most recent call first): File "threading.py", line 297 in wait File "zeroconf\__init__.py", line 2117 in wait File "zeroconf\__init__.py", line 1262 in run File "threading.py", line 914 in _bootstrap_inner File "threading.py", line 882 in _bootstrap Thread 0x0000292c (most recent call first): File "zeroconf\__init__.py", line 1183 in run File "threading.py", line 914 in _bootstrap_inner File "threading.py", line 882 in _bootstrap Thread 0x00003808 (most recent call first): File "C:\Program Files\Ultimaker Cura 4.7\plugins\USBPrinting\USBPrinterOutputDeviceManager.py", line 87 in _updateThread File "threading.py", line 862 in run File "threading.py", line 914 in _bootstrap_inner File "threading.py", line 882 in _bootstrap Thread 0x000050f8 (most recent call first): File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\Backend\Backend.py", line 165 in _storeStderrToLogThread File "threading.py", line 862 in run File "threading.py", line 914 in _bootstrap_inner File "threading.py", line 882 in _bootstrap Thread 0x0000484c (most recent call first): File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\Backend\Backend.py", line 153 in _storeOutputToLogThread File "threading.py", line 862 in run File "threading.py", line 914 in _bootstrap_inner File "threading.py", line 882 in _bootstrap Thread 0x00003304 (most recent call first): File "threading.py", line 293 in wait File "threading.py", line 424 in acquire File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 98 in _nextJob File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 123 in run File "threading.py", line 914 in _bootstrap_inner File "threading.py", line 882 in _bootstrap Thread 0x000030e4 (most recent call first): File "C:\Users\flkar\AppData\Roaming\cura\4.7\plugins\SettingsGuide2\SettingsGuide2\CuraSettingsGuide.py", line 295 in _getArticle File "C:\Users\flkar\AppData\Roaming\cura\4.7\plugins\SettingsGuide2\SettingsGuide2\CuraSettingsGuide.py", line 158 in load_all File "C:\Users\flkar\AppData\Roaming\cura\4.7\plugins\SettingsGuide2\SettingsGuide2\CuraSettingsGuide.py", line 143 in run File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 132 in run File "threading.py", line 914 in _bootstrap_inner File "threading.py", line 882 in _bootstrap Thread 0x000043a4 (most recent call first): File "threading.py", line 293 in wait File "threading.py", line 424 in acquire File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 98 in _nextJob File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 123 in run File "threading.py", line 914 in _bootstrap_inner File "threading.py", line 882 in _bootstrap Thread 0x00004acc (most recent call first): File "threading.py", line 293 in wait File "threading.py", line 424 in acquire File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 98 in _nextJob File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 123 in run File "threading.py", line 914 in _bootstrap_inner File "threading.py", line 882 in _bootstrap Current thread 0x00004c58 (most recent call first): File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 393 in _logInfoWidget File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 182 in _createDialog File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 86 in __init__ File "X:\4.7-exe\build\inst\bin\cura_app.py", line 166 in exceptHook File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\UM\Qt\QtApplication.py", line 378 in exec_ File "X:\4.7-exe\build\inst\lib\python3.5\site-packages\cura\CuraApplication.py", line 844 in run File "X:\4.7-exe\build\inst\bin\cura_app.py", line 234 in <module> File "Console.py", line 24 in <module> File "<frozen importlib._bootstrap>", line 634 in _load_backward_compatible File "<frozen importlib._bootstrap>", line 664 in _load_unlocked File "<frozen importlib._bootstrap>", line 957 in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 968 in _find_and_load File "__startup__.py", line 12 in <module> File "<frozen importlib._bootstrap>", line 634 in _load_backward_compatible File "<frozen importlib._bootstrap>", line 664 in _load_unlocked File "<frozen importlib._bootstrap>", line 957 in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 968 in _find_and_load
I am going to try to reinstall and have it remove the old profiles and see if that works.
In cura if you do "helpl" "Show Configuration Folder" and then you delete that folder tree and restart cura it will recreate a fresh copy of default profiles in there and Cura won't crash anymore.
The bad thing about this is that you lose any profiles you created.
There are 2 schools of thought with saving your settings. One is to save your settings in "profiles". The other is to save them in "project files" (thirdly some people use paper - not me). I do the later as it seems more dependable and I can load very old project files into much newer versions of Cura and it always works fine for me. This has the added benefit that if someone points to a 5 year old print and says "what were the settings?", I have it. Saved forever. Including orientation of STL and scale of part (if I scaled it up or down) and so on.
QuoteIn cura if you do "helpl" "Show Configuration Folder" and then you delete that folder tree and restart cura it will recreate a fresh copy of default profiles in there and Cura won't crash anymore.
Unfortunately that didn't work for me, it still crashes every time I try to open an STL. I completely deleted the cura folder in appdata as well as fully reinstalled cura. I'm unable to open any STLs at all without it crashing.
Same for me. I just tried it. Still crashes when I open an STL.
Well, there seem to be multiple issues here. I loaded the update on a laptop that's never had the software installed and it loaded the STL. However when I created my own filament profile, all of the print profiles disappeared and it won't actually let me import or create one. Even the default profiles are gone.
I cannot edit the post, but the solution to the problem with the missing profiles is on Github:
I think the problem is that every time Cura 4.7 restarts, it re-grabs the profile data from 4.6 or earlier versions. You have to delete *all* your profile data from previous versions before restarting Cura 4.7, and only then will 4.7 run properly.
Needless to say, losing all my carefully curated profiles is *completely* unacceptable, and I have dropped back to 4.6.2 until Ultimaker gets their crap together and fixes this ridiculous problem.
29 minutes ago, prof_west said:I think the problem is that every time Cura 4.7 restarts, it re-grabs the profile data from 4.6 or earlier versions
Well......that's possible. However,. I have multiple folders of old profiles and I've never had Cura crash before v4.7. If this is true than it's related to something introduced into 4.7, from my experience.
I'm the same, I had configuration files from 4.4, 4.5 and 4.6 on this PC.
It is easy to try it for yourself. Move all of the folders from "C:\Users\*your username*\AppData\Roaming\cura" to a temporary directory. Restart Cura 4.7.
When I did this, it ran fine. But if I restored from backup, it would start crashing again. If I deleted the 4.7 profile data, put the old profile data back, then restarted 4.7, crashing again. Something in 4.7 is terribly broken when it tries to use the old profiles.
So, I figure choices are stay with 4.6 for now and wait until 4.7 is fixed, or rebuild all your profiles.
[EDIT] I should say, everything works fine for my Ultimaker S3. It only crashes when I select my Ender 3 as the printer.
Edited by prof_west14 hours ago, KaraokeAmerica said:Cura 4.7 crashes every time I try to open an STL file.
Fix is already read to be tested -> https://github.com/Ultimaker/Uranium/pull/633
8 hours ago, Taubin said:Well, there seem to be multiple issues here. I loaded the update on a laptop that's never had the software installed and it loaded the STL. However when I created my own filament profile, all of the print profiles disappeared and it won't actually let me import or create one. Even the default profiles are gone.
See the info on this issue: https://github.com/Ultimaker/Cura/issues/8229
7 hours ago, prof_west said:I think the problem is that every time Cura 4.7 restarts, it re-grabs the profile data from 4.6 or earlier versions. You have to delete *all* your profile data from previous versions before restarting Cura 4.7, and only then will 4.7 run properly.
Get our crap together? Excuse me? You're using an open source product, on hardware that we don't sell or support. We don't even have those third party printers nor the capacity (and desire) to actually test them.
So if you want to prevent issues like that, pleas use the beta and report these issues during the beta. As you can see, i've managed to create a fix for this within a single hour of this being reported.
We test Cura as much as we can, but we greatly focus on Ultimaker machines since 99% of the development of Cura is paid from the revenus of Ultimaker.
Sigh. I should've come to the forum before updating... I lost all my profiles. Help!
nallath 1,123
Nope. For third party machines we rely on outside contributions. Unfortunately, no-one made the contribution so far.
