@nallath: watch out the post from May 14h, there was attached the log file.
Can't log into the site via Untilmaker Cura 4.9.1. I either get a message in Firefox, which is the same browser I'm using to access your site, that says "Problem loading page" or
UltimakerAccount
Not signed in
Please allow the application to access the requested data. You can do this by signing in again and clicking Allow. There is no Allow to click.
Edited by cfrank01misspelling
@Ohyst60 Try disabling "Use Towers" option in the support section
- 2
19 hours ago, pawPrinter said:@Ohyst60 Try disabling "Use Towers" option in the support section
Thanks! that worked 🙂 (No bug ?) Why towers was enabled ... too many settings, I loose overview.
- 1
Can't see any materials installed from marketplace. if i view in marketplace it says installed, but materials nowhere to be found
The materials in the Marketplace only come with profiles for Ultimaker printers, which are all 2.85 mm only.
Cura 4.9.1 wont load. It was woking fine and then it was not... When I start the program. The loading window appears and then it freezes. I uninstalled and installed again. Nothing changed, same problem.
On 5/18/2021 at 8:32 PM, GregValiant said:@gsar333 What printer is that? I haven't seen that sort of problem before.
Its the CR10-s Pro.
On 5/18/2021 at 10:30 PM, mrpresident said:This is not related to the main topic which was the not loading 4.9.x on Windows 7....
I´m not interested about failures on a MAC!!!
The topic was the release of the new version. Try not to be a dick and be helpful instead.
GregValiant 1,318
Hi @gsar333. I'm running Win10 Home 64 bit and Cura 4.9.1. My video is in "compatibility mode" (this older video system doesn't support OpenGL 4.1). I loaded a CR10-S Pro and it looks fine. It appears that your view of the build volume is skewed even when ignoring the background mesh/machine.
Have you toggled between Perspective View and Orthographic View (Preferences | Configure Cura | Viewport Behavior) and does the problem occur in both modes?
11 hours ago, GregValiant said:
11 hours ago, GregValiant said:Hi @gsar333. I'm running Win10 Home 64 bit and Cura 4.9.1. My video is in "compatibility mode" (this older video system doesn't support OpenGL 4.1). I loaded a CR10-S Pro and it looks fine. It appears that your view of the build volume is skewed even when ignoring the background mesh/machine.
Yep none of those views work. The entire placement/perspective is completely off and the zoom or vanishing point isn't even on the printer but high to the right behind the printer. Rather than zoom to the build plate or middle of the screen it always zooms to the top right of the screen making it completely unusable.
GregValiant 1,318
Next, when I click and hold my scroll button/middle button I can drag the build plate around. (That's what I have to do in Orthogonal because "scroll to mouse pointer" doesn't work for me when in orthogonal.)
At any rate, if you can drag it to the center maybe you can get by for a bit.
I haven't seen that problem before but I'm just a rummy dumb who came in off the street. if you post a log file maybe someone from the team will see something. In Cura go to Help | Show Configuration Folder and you will find Cura.log. Close Cura, go to the location and delete Cura.log. Restart Cura and the file will be created again but much shorter. Bring in a model and do what you do moving it around. Close Cura and post the log file here. Posting the info about your computer, Operating System, video card, etc. will help as well.
On 6/1/2021 at 2:51 PM, duf180 said:
Having this exact issue, were you able to find a solution/workaround?
I had this problem as well. It may have started after the latest MacOS update, but I can't say for sure. Regardless, I noticed this in the log file:
2021-06-11 15:51:17,091 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.parseJWT [114]: Checking the access token for [https://account.ultimaker.com/check-token] 2021-06-11 15:51:17,299 - DEBUG - [JobQueWorker [2]] UM.Mesh.MeshData.calculateNormalsFromVertices [556]: Calculating normals took 0.00214385986328125 seconds 2021-06-11 15:51:17,496 - WARNING - [MainThread] cura.OAuth2.AuthorizationHelpers.parseJWT [123]: Could not retrieve token data from auth server: {"errors": [{"id": "dec451e5-b44e-457c-9aef-bc6a198ad3b1", "code": "invalidToken", "http_status": "403", "title": "The given token is invalid.", "meta": {"error_type": "AuthError", "url": "https://account.ultimaker.com/check-token"}}]} 2021-06-11 15:51:17,502 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [61]: Refreshing the access token for [https://account.ultimaker.com] 2021-06-11 15:51:17,813 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [250]: Attempting to store the auth data for [https://account.ultimaker.com] 2021-06-11 15:51:17,817 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.parseJWT [114]: Checking the access token for [https://account.ultimaker.com/check-token] 2021-06-11 15:51:18,116 - WARNING - [MainThread] cura.OAuth2.AuthorizationHelpers.parseJWT [123]: Could not retrieve token data from auth server: {"errors": [{"id": "0be11182-6748-4790-8c93-b60dc848d01c", "code": "invalidToken", "http_status": "403", "title": "The given token is invalid.", "meta": {"error_type": "AuthError", "url": "https://account.ultimaker.com/check-token"}}]}
Once I saw that, I removed the following line from the cura.cfg file and that seemed to fix it:
ultimaker_auth_data =
- 2 weeks later...
Ubuntu 20.04.2 LTS, 64 bit - Cura 4.9.1 doesn't start. I reinstalled (removed and installed) through snap - it doesn't help. Cannot find any logs or .conf. How to completely remove all cura files and install again or where to find error logs?
20 hours ago, upbl said:Ubuntu 20.04.2 LTS, 64 bit - Cura 4.9.1 doesn't start. I reinstalled (removed and installed) through snap - it doesn't help. Cannot find any logs or .conf. How to completely remove all cura files and install again or where to find error logs?
We don't provide anything via snap. THe only thing that we provide (and support) is the appimage.
Info about log files can be found here: https://github.com/ultimaker/cura/#logging-issues
- 2
Instead of using the snap, try using the AppImage as provided by Ultimaker. Ultimaker does not test or support the snap, nor any other version of Cura for linux other than the AppImage.
- 2
- SandervG unpinned this topic
- 1 month later...
Thanks for this! I was having the same issue where 4.9.1 would not start and I found the same token AuthErrors repeating in the log. Removing that line from cura.cfg immediately fixed the problem.
The issue was fixed by ahoeben for the 4.10 release, so updating should also do the trick.
- 1
9
8
5
5
Popular Days
Apr 21
17
Apr 27
6
May 20
6
Jun 2
6
mrpresident 9 posts
ahoeben 8 posts
nallath 5 posts
gsar333 5 posts
Popular Days
Apr 21 2021
Apr 27 2021
May 20 2021
Jun 2 2021
Popular Posts
nallath
We missed the dual extrusion issue. It's something that we should have caught but didn't. Since a lot of people have also reported this on github (thanks for that!), we already have fix for this and h
fvrmr
Ultimaker Cura 4.9 We are happy to announce that the Ultimaker Cura 4.9 is here. This release contains a bundle of bug fixes and feature improvements. This will increase software stabilit
moo00se
Just installed 4.9. When I go to File>Open, Cura crashes. Windows 10.
Posted Images
nallath 1,123
Without logs, there is really nothing we can do to help you.
As i've said before; Please report issues on github and fill in the bug template. We ask people to do that because you need to help us in order for us to be able to help you.
gr5 2,196
log file here:
%APPDATA%\cura\<Cura version>\cura.log (Windows), or usually C:\Users\\<your username>\AppData\Roaming\cura\<Cura version>\cura.log
Priddy 10
Also recommended to grab the DxDiag logs as well, when submitting to GitHub:
DirectX diagnostics (Windows only): Go to 'Start', in the search box type 'dxdiag' and hit enter. In the dxdiag dialog, click 'save all information' in the bottom right corner.
https://support.ultimaker.com/hc/en-us/articles/360016538000-Saving-Ultimaker-Cura-logs
