@Franny500 - does it need to *look* like egg crate? Can it be brown? If it only needs to *look* like that then try wood filled pla. Several companies make this filament.
If you want it to *feel* like egg carton then I recommend you 3dprint permeable molds and then use actual paper pulp to make your finished part. This is pretty easy to do I suspect. People have posted about it:
http://www.javelin-tech.com/3d-printer/making-molded-pulp-packages-in-low-quantities/
and Cura makes it easy to print lots of holes in your print for the water to drain out - for example you can set the infill percent to control "hole size" and turn off top/bottom layers.
1
318
31
28
28
Popular Days
Dec 18
24
Dec 9
13
Nov 17
11
Jan 6
9
cloakfiend 318 posts
geert_2 31 posts
SandervG 28 posts
KevinMakes 28 posts
Popular Days
Dec 18 2015
Dec 9 2015
Nov 17 2017
Jan 6 2016
Popular Posts
cloakfiend
ACETONE AND COLORFABB RED TR FILAMENT EXPLAINED AGAIN....HOPEFULLY A BIT BETTER Ok so I have a bit of time spare during my night shift so I thought I'd have another go at explaining how th
geert_2
Results before and after "acetoning". These are just old scrap pieces, which I kept around for testing. Material is colorFabb PLA/PHA, Dutch Orange. Printed with 0.4mm nozzle,
geert_2
Thanks for the info. So I will go the "cooking way", and just experiment. :) The shrinking might be a bit of a problem though, as the silicone castings should keep their shape and fit: th
Posted Images
cloakfiend 995
Just for the record.....same filament.
