Dim3nsioneer 557
@foehnsturm: Great use case! Is it more or less as flexible as a real human spine?
foehnsturm 969
!!! Can you make me a knee? I would like it to take away
Great print !!
Well I should test it with my knee first
- 1
foehnsturm 969
Never had a real one in my hands 8)
But I assume, at little less flexible. I'll run another print with only 2 perimeter lines instead of 3, and even lower temp.
Edited by GuestHi foehnsturm
Where did you get the CAD template for the model come from?
Would like to try to print.
Thank you and greet
Marin
Edited by Guestfoehnsturm 969
... https://grabcad.com/library/human-spine-1
Geometry is not so much the challenge but using Filaflex which is one most difficult to print flexible filaments on bowden setups (and with a standard UM 2+ feeder).
Thanks, I try my luck
May I ask, what type of pancake NEMA17 that is? ebay/aliexpress etc didn't show results...
Have you tried a little light oil in the Bowden tube?
I modified Roberts guide for the feeder and I now have a small hole running through from the back, I then insert a small pipe cleaner in with a few drops of oil on it . I still get the odd bit of under extrusion from FilaFlex from Recrues but I like the filament.
foehnsturm 969
I used that trick already. But the current print was intended as challenge for the the Machtless block and Race nozzle. Just wanted to see if this one performs better with Filaflex. And so far it looks like that..
- 3
foehnsturm 969
- 5 weeks later...
foehnsturm 969
That looks sexy!
Edited by Guest- 1
Any release info on a kit? Looks pretty good!
foehnsturm 969
Still under discussion ...
Another test:
https://ultimaker.com/en/community/prints/4900-how-small-can-we-go
- 3
maybe you need help from lance to go even smaller
https://ultimaker.com/en/stories/17378-worlds-tiniest-drill-created-through-big-ambition
- 2 weeks later...
foehnsturm 969
Green? Looks like the black pla-tec that I use from extrudr. If it's that one, I had to change the filament size from 1.75 to 1.725 to keep a perfect top layer. Also imo it needs like 5-7C + of heat vs the same print done on faberdashery.
foehnsturm 969
It's the extrudr stuff andprinted quite well. But the support was more stringy than I expected.
- 2 weeks later...
Wow, 3d printing has come on a bit since I last logged in a few months ago! Still leading the field foehnstrum i see! Great work
- 1
foehnsturm 969
- 3
Woah! That's pretty cool.
280
228
170
133
Popular Days
Jul 14
22
Mar 26
19
Feb 13
18
Sep 23
17
foehnsturm 280 posts
neotko 228 posts
ultiarjan 170 posts
macua85 133 posts
Popular Days
Jul 14 2015
Mar 26 2015
Feb 13 2015
Sep 23 2015
Posted Images
Labern 774
Thanks.
Yes time does fly by and I had an amazing time. The first week was the best though
