22-09-15 14:49:42,351 Cura[534]: 2015-09-22 14:49:42,351 - INFO - Loaded plugin ConsoleLogger
22-09-15 14:49:42,371 Cura[534]: 2015-09-22 14:49:42,370 - INFO - Loaded plugin OBJReader
22-09-15 14:49:42,381 Cura[534]: 2015-09-22 14:49:42,380 - INFO - Loaded plugin OBJWriter
22-09-15 14:49:42,392 Cura[534]: 2015-09-22 14:49:42,391 - INFO - Loaded plugin STLReader
22-09-15 14:49:42,403 Cura[534]: 2015-09-22 14:49:42,402 - INFO - Loaded plugin STLWriter
22-09-15 14:49:42,414 Cura[534]: 2015-09-22 14:49:42,413 - INFO - Loaded plugin FileLogger
22-09-15 14:49:42,444 Cura[534]: 2015-09-22 14:49:42,444 - INFO - Loaded plugin LocalFileOutputDevice
22-09-15 14:49:42,483 Cura[534]: 2015-09-22 14:49:42,482 - INFO - Loaded plugin CameraTool
22-09-15 14:49:42,504 Cura[534]: 2015-09-22 14:49:42,503 - INFO - Loaded plugin MirrorTool
22-09-15 14:49:42,543 Cura[534]: 2015-09-22 14:49:42,542 - INFO - Loaded plugin PerObjectSettingsTool
22-09-15 14:49:42,597 Cura[534]: 2015-09-22 14:49:42,596 - INFO - Loaded plugin RotateTool
22-09-15 14:49:42,650 Cura[534]: 2015-09-22 14:49:42,649 - INFO - Loaded plugin ScaleTool
22-09-15 14:49:42,676 Cura[534]: 2015-09-22 14:49:42,675 - INFO - Loaded plugin SelectionTool
22-09-15 14:49:42,696 Cura[534]: 2015-09-22 14:49:42,695 - INFO - Loaded plugin TranslateTool
22-09-15 14:49:42,814 Cura[534]: 2015-09-22 14:49:42,813 - INFO - Checking for new version of cura
22-09-15 14:49:42,814 Cura[534]: 2015-09-22 14:49:42,813 - INFO - Loaded plugin UpdateChecker
22-09-15 14:49:42,855 Cura[534]: 2015-09-22 14:49:42,854 - INFO - Loaded plugin MeshView
22-09-15 14:49:42,873 Cura[534]: 2015-09-22 14:49:42,872 - INFO - Loaded plugin WireframeView
22-09-15 14:49:42,930 Cura[534]: 2015-09-22 14:49:42,929 - INFO - Loaded plugin 3MFReader
22-09-15 14:49:42,951 Cura[534]: 2015-09-22 14:49:42,950 - INFO - Loaded plugin ChangeLogPlugin
22-09-15 14:49:43,211 Cura[534]: 2015-09-22 14:49:43,211 - INFO - Loaded plugin CuraEngineBackend
22-09-15 14:49:43,229 Cura[534]: 2015-09-22 14:49:43,228 - INFO - Loaded plugin GCodeWriter
22-09-15 14:49:43,275 Cura[534]: 2015-09-22 14:49:43,275 - INFO - Loaded plugin LayerView
22-09-15 14:49:43,309 Cura[534]: 2015-09-22 14:49:43,308 - INFO - Loaded plugin PostProcessingPlugin
22-09-15 14:49:43,349 Cura[534]: 2015-09-22 14:49:43,348 - INFO - Loaded plugin RemovableDriveOutputDevice
22-09-15 14:49:43,393 Cura[534]: 2015-09-22 14:49:43,392 - INFO - Loaded plugin SliceInfoPlugin
22-09-15 14:49:43,584 Cura[534]: 2015-09-22 14:49:43,583 - INFO - Loaded plugin USBPrinting
22-09-15 14:49:43,630 Cura[534]: 2015-09-22 14:49:43,629 - INFO - Started engine process: /Applications/Cura 15.09.83.app/Contents/MacOS/CuraEngine
22-09-15 14:49:43,924 Cura[534]: 2015-09-22 14:49:43,923 - DEBUG - Setting value of setting infill_sparse_density to 5
22-09-15 14:49:43,924 Cura[534]: 2015-09-22 14:49:43,923 - DEBUG - Setting value of setting shell_thickness to False
22-09-15 14:49:43,925 Cura[534]: 2015-09-22 14:49:43,924 - DEBUG - Setting value of setting support_connect_zigzags to True
22-09-15 14:49:43,925 Cura[534]: 2015-09-22 14:49:43,925 - DEBUG - Setting value of setting support_type to buildplate
22-09-15 14:49:43,926 Cura[534]: 2015-09-22 14:49:43,925 - DEBUG - Setting value of setting top_bottom_pattern to concentric
22-09-15 14:49:43,926 Cura[534]: 2015-09-22 14:49:43,925 - DEBUG - Setting value of setting support_pattern to grid
22-09-15 14:49:43,927 Cura[534]: 2015-09-22 14:49:43,926 - DEBUG - Setting value of setting skin_alternate_rotation to False
22-09-15 14:49:43,930 Cura[534]: 2015-09-22 14:49:43,929 - DEBUG - Setting value of setting infill_sparse_density to 50
22-09-15 14:49:43,930 Cura[534]: 2015-09-22 14:49:43,930 - DEBUG - Setting value of setting meshfix_extensive_stitching to False
22-09-15 14:49:43,931 Cura[534]: 2015-09-22 14:49:43,930 - DEBUG - Setting value of setting print_sequence to one_at_a_time
22-09-15 14:49:43,931 Cura[534]: 2015-09-22 14:49:43,931 - DEBUG - Setting value of setting magic_mesh_surface_mode to surface
22-09-15 14:49:43,932 Cura[534]: 2015-09-22 14:49:43,931 - DEBUG - Setting value of setting meshfix_union_all_remove_holes to False
22-09-15 14:49:43,932 Cura[534]: 2015-09-22 14:49:43,932 - DEBUG - Setting value of setting skirt_line_count to True
22-09-15 14:49:43,933 Cura[534]: 2015-09-22 14:49:43,932 - DEBUG - Setting value of setting meshfix_keep_open_polygons to False
22-09-15 14:49:43,936 Cura[534]: 2015-09-22 14:49:43,935 - DEBUG - Setting value of setting layer_height to 0.06
22-09-15 14:49:43,939 Cura[534]: 2015-09-22 14:49:43,938 - DEBUG - Setting value of setting layer_height to 0.1
22-09-15 14:49:43,948 Cura[534]: 2015-09-22 14:49:43,947 - DEBUG - Backend connected on port 49674
22-09-15 14:49:43,971 Cura[534]: 2015-09-22 14:49:43,971 - DEBUG - Setting active view to MeshView
22-09-15 14:49:44,159 Cura[534]: 2015-09-22 14:49:44,159 - DEBUG - Calculating normals took 0.002402067184448242 seconds
22-09-15 14:49:44,160 Cura[534]: 2015-09-22 14:49:44,159 - DEBUG - Loaded a mesh with 10452 vertices
22-09-15 14:49:45,979 Cura[534]: 2015-09-22 14:49:45,978 - DEBUG - Loaded theme /Applications/Cura 15.09.83.app/Contents/Resources/cura/resources/themes/cura
22-09-15 14:49:52,231 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Menu.qml:146: TypeError: Cannot read property '__contentItem' of null
22-09-15 14:49:52,232 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Menu.qml:146: TypeError: Cannot read property '__contentItem' of null
22-09-15 14:49:52,232 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/cura/resources/qml/SidebarHeader.qml:85:31: Unable to assign [undefined] to int
22-09-15 14:49:52,286 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
22-09-15 14:49:52,294 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
22-09-15 14:49:52,306 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
22-09-15 14:49:52,311 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
22-09-15 14:49:52,320 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
22-09-15 14:49:52,328 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
22-09-15 14:49:52,336 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
22-09-15 14:49:52,341 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
22-09-15 14:49:52,355 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
22-09-15 14:49:52,371 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
22-09-15 14:49:52,373 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/QtQuick/Controls/Styles/Base/ButtonStyle.qml:154: TypeError: Cannot read property of null
22-09-15 14:49:52,423 Cura[534]: 2015-09-22 14:49:52,422 - DEBUG - Preparing to send slice data to engine.
22-09-15 14:50:01,814 Cura[534]: 2015-09-22 14:50:01,813 - DEBUG - Preparing to send slice data to engine.
22-09-15 14:50:03,739 Cura[534]: QFileInfo::absolutePath: Constructed with empty filename
22-09-15 14:50:04,355 Cura[534]: assertion failed: 14F27: libxpc.dylib + 62447 [5C829202-962E-3744-8B50-00D38CC88E84]: 0x89
22-09-15 14:50:07,928 Cura[534]: 2015-09-22 14:50:07,927 - DEBUG - Calculating normals took 0.00032210350036621094 seconds
22-09-15 14:50:07,928 Cura[534]: 2015-09-22 14:50:07,928 - DEBUG - Loaded a mesh with 72 vertices
22-09-15 14:50:07,932 Cura[534]: 2015-09-22 14:50:07,932 - DEBUG - Loading mesh took 0.10672307014465332 seconds
22-09-15 14:50:08,621 Cura[534]: 2015-09-22 14:50:08,620 - DEBUG - Preparing to send slice data to engine.
22-09-15 14:50:08,642 Cura[534]: 2015-09-22 14:50:08,641 - DEBUG - Sending data to engine for slicing.
22-09-15 14:50:14,422 Cura[534]: 2015-09-22 14:50:14,421 - DEBUG - Setting active view to LayerView
22-09-15 14:50:22,495 Cura[534]: 2015-09-22 14:50:22,494 - DEBUG - Setting value of setting infill_sparse_density to 2
22-09-15 14:50:22,498 Cura[534]: 2015-09-22 14:50:22,497 - DEBUG - Setting value of setting infill_sparse_density to 2
22-09-15 14:50:22,498 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/UM/Settings/SettingView.qml:119:35: QML SettingItem: Binding loop detected for property "value"
22-09-15 14:50:22,499 Cura[534]: file:///Applications/Cura 15.09.83.app/Contents/Resources/qml/UM/Settings/SettingView.qml:119:35: QML SettingItem: Binding loop detected for property "value"
22-09-15 14:50:24,354 Cura[534]: 2015-09-22 14:50:24,353 - DEBUG - Preparing to send slice data to engine.
22-09-15 14:50:24,356 Cura[534]: 2015-09-22 14:50:24,356 - WARNING - The setting skirt_line_count has an invalid value of True
22-09-15 14:50:24,357 Cura[534]: 2015-09-22 14:50:24,356 - WARNING - Profile has error values. Aborting slicing
22-09-15 14:50:26,894 Cura[534]: 2015-09-22 14:50:26,893 - DEBUG - Setting value of setting infill_sparse_density to
22-09-15 14:50:27,423 Cura[534]: 2015-09-22 14:50:27,422 - DEBUG - Preparing to send slice data to engine.
22-09-15 14:50:27,426 Cura[534]: 2015-09-22 14:50:27,425 - WARNING - The setting skirt_line_count has an invalid value of True
22-09-15 14:50:27,426 Cura[534]: 2015-09-22 14:50:27,426 - WARNING - Profile has error values. Aborting slicing
22-09-15 14:50:28,214 Cura[534]: 2015-09-22 14:50:28,213 - DEBUG - Setting value of setting infill_sparse_density to 5
22-09-15 14:50:28,669 Cura[534]: 2015-09-22 14:50:28,669 - DEBUG - Setting value of setting infill_sparse_density to 50
22-09-15 14:50:29,150 Cura[534]: 2015-09-22 14:50:29,149 - DEBUG - Preparing to send slice data to engine.
22-09-15 14:50:29,154 Cura[534]: 2015-09-22 14:50:29,153 - WARNING - The setting skirt_line_count has an invalid value of True
22-09-15 14:50:29,155 Cura[534]: 2015-09-22 14:50:29,154 - WARNING - Profile has error values. Aborting slicing
69
13
13
10
Popular Days
Sep 4
15
Sep 22
14
Mar 12
10
Sep 10
9
nallath 69 posts
peggyb 13 posts
ultiarjan 13 posts
ahoeben 10 posts
Popular Days
Sep 4 2015
Sep 22 2015
Mar 12 2016
Sep 10 2015
Posted Images
nallath 1,123
That's the engine log file, I'm looking for the application log. You should be able to find that at $User/.cura/cura.log
