Hi dim3nsioneer
Ja beide Düsen Ø 0,4mm.
Das Polysupport Material lässt sich gut drucken, da ist es nicht erforderlich.
Ich habe mein PVA Material getestet welches ich hier habe, mit einer 0.8mm Düse.
Drucken lässt es sich gut, nur die Haftung zum anderen Werkstoff ist nicht vorhanden.
Gruß
Marin
ultiarjan 1,209
I think there are video's using the wizzard, but I never got it to work, manual is just quicker.
It's been a while since I did it (so I probably forget stuff) but it's roughly like this;
- load the 2 stl's of your dual print.
- select them
- hold "shift" and click "center and arrange" to merge the models
- create 2 processes
- set the extruder in one process to 0 and in the other to 1
- set the other setting as you like (nozzle, temp, speed etc etc etc
- in each process SELECT MODELS (bottom left of window) to allocate one of the stl's to a process (warning, I think by default both stl's are allocated to all processes.
There is a way (after you set the stuff that needs to be different like allocate model, and extruder number) to combine the to processes so if you change something in one its also changed in the other. Select both processes, go to "edit" / "group selection"
You set the tool change script in the script tab of each process.
You set the toolchange retraction in the advanced tab of each process.
example of the toolchange script I used on the magnetic head setup, obviously you don't need the change movements, but it's good to know f.e. the {IF NEWTOOL=1} function.
https://ultimaker.com/en/community/10657-a-different-multi-extrusion-approach-um-tool-printhead-changer?page=10#reply-106547
looking at an old file i think I first created one process with 2 extruders, called them primary and secondary (one = T0, other T1), then copied the process, and in the 2th propces set extruder to the "secondary")
Edited by GuestLink to post
zerspaner_gerd 235
Hallo Marin,
genauso wie ultiarjan geschrieben hat bin ich auch am Testen/versuchen (Layer Preview) einfach "Tool" T0 und T1 in 2 verschiedene Processe + Tool Change Scripts.
@martin-hillenbrand hatte ein dual fähiges Druckerprofil verwendet und die Einstellungen an den UM2 abgeändert, den ein zigsten Vorteil wo ich da gesehen habe das man den Extruder, oben rechts, auswählen kann.
Gruß Gerd
Crema 123
Simplify 3D hat schon sehr viele Einstellmöglichkeiten.
Da muss ich noch etwas üben um gute Reproduzierbare Ergebnisse zu erhalten.
Ich habe mir ein Supportmaterial bestellt, das Polysupport von Polymaker.
Laut Hersteller soll er super einfach sein, das Support Material vom Druckobjekt zu entfernen.
Gestern kam das bestellte Material und gleich mal ein Test Objekt gedruckt.
Nicht gerade das schwierigste, aber die Einstellungen haben auf Anhieb gepasst und das Ergebnis seht ihr hier.
Das Material lässt sich in der Tat ganz einfach mit dem Finger wegbrechen.
Das Bauteil von unten nach dem Entfernen vom Support.
Von unten
von oben.
Den CNC Code mit Cura erstellt
Druckeinstellungen:
Düse 1: Material ABS blau, Temp 255°C,
Düse 2: Material Polysupport, Temp 230°C
Layer: 0,10mm
Speed: 60mm/s
Ein weiteres PVA Material habe ich mit bestellt und zwar das Scaffold.
Sobald das geliefert wird, in 2-3 Wochen :( teste ich das mal.
Zudem habe ich mir PLA Material von Colorfabb bestellt, mal schauen wie gut sich das Verarbeiten lässt.
Fragen?
Gerne!
Gruß
Marin
Dim3nsioneer 528
Beide Düsen mit 0.4mm Durchmesser?
Würde es Sinn machen, das Supportmaterial mit einer grösseren Düse zu drucken? Muss ja nicht schön werden...
