I'm an UMO user, so I am not exactly familiar with the UM2/+ feeders. I would assume there is a set screw holing the drive wheel on? You might try some loctite on that screw, possibly adding another set screw at 90 degrees + threadlocker. Would hub-locking compound be helpful? I don't know if gluing on the hub would make disassembly/maintenance otherwise difficult, but Loctite makes a number of semi-permanent hub locking solvents that would essentially make the hub connection rigid. Something like Loctite 648 might do it.
I might be interested in picking up a used UM2+ if you're selling. If so, PM me what you want for it. May also depend on your location.
Torgeir 244
Hi Philippe,
I'll think everyone in here understand your frustration, so no worry..
I'd post to you lastly, but did not know you had a UM2+ version.
I have a "self made" "UM2 ext", but never had anything like your problems.
However, I've been looking into this problem for a long time as several have had/have this problem frequently with the UM2 versions. The latter problem you have is very well known as a few people have been reporting this here. I'll think someone cleaned well and used super glue, not so sure about this method, but someone will sure chime in.
I'll think that if you manage to fix the stepper gear, your printer should be fine.
So good luck.
Thanks.
Torgeir.
