Is there a way to change the currency for the filament cost?
I got the confirmation that these names were generated 'on purpose', so someone would come up with a better name. Or perhaps it was just a lack of coffee.
I can confirm that this was not a lack of coffee, as I don't work before I have had some double expressos. I do like a recent suggestion from the community: Coarse and Very Coarse. Then maybe we could call high and normal: Very Fine and Fine. But what is faster/draftier/coarser: Draft or Coarse? Struggles....:angry:
- 2
qwerty8224 16
Multithreading and it works
Faster cut layers:P:P:P
- 1
Check the general preferences, next to the language-selection
- 1
Found two things. Cura won't use a language change.
And, if i set my own gcode for temps, Cura set this temps but place its own temp code in the beginning of the gcode also. In 2.4 Cura set no own temps when the variables for this was in the gcode.
That worked, thank you!
Is it too hard to implement zoom in direction of mouse pointer?
viewing layer view and multiple parts sucks without it.
- Draft print
- Rough Draft print
- Brutal Draft print
- 1
- hurry up
- Im impatient
- I want it now
- 1
Not a bug, but has turning off the perspective in the viewer ever been tried? Would it be hard to implement? I would find this to be an advantage, along with being able to look straight down at the bed. for placing objects, and analyzing layer by layer... Most mechanical CAD systems I have ran have perspective as an option, and most users in my experience prefer it off.
I tried it briefly. It did not work straight away, and there were more important things to do, so I lost interest and moved on. But I could revisit this if I find some time.
I don't know, is it too hard to suggest this as a feature without sounding like a nag? ;-)
There are lots of things that may not be too hard to implement, but there is a limited amount of time.
Ask nicely, and make sure the usecase or usability improvement is clear, and it may get implemented.
Yeah, it does sound like a nag when I read it now. But it wasn't my intention.
Most CAD packages zoom into the area where the mouse pointer is pointing when you scroll the mouse wheel.
This allows you to point at a part you want to zoom into and scroll the wheel to get a closer look in that direction.
No problem.
You do make a valid point with the zooming. It would be a shame if it gets lost in this thread. Posting requests like this on github has a larger chance of being noticed (and remembered!) by devs. http://github.com/ultimaker/cura/issues
- 1
Cookies are not even required anymore?.. what happened?
Edited by Guest- 1
I know right?
not even Stroopwaffles?
- 1
Well... required.. That makes it sound so mercenary. Let's just say that it wont hurt the odds of it getting done
- 1
No problem.
I second the zooming suggestion. I wind up doing a lot of moving around to see what I want to see the first time! SolidWorks and others have that same zoom where the mouse is feature. Thanks!
SandervG 1,521
nallath 1,123
As for the name; The best other name we could come up with is Drafty McDraftFace. So yeah, It's probably best if some of you can come up with something better
nallath 1,123
Eeh. Not really. I kinda dislike Asana.
