Really? So there are 2 different sides on the original glass? This is extremely important information!
Never knew this. Some glasses, (i have about 5 on the UM3 and 2 on the UM5) are turned over because of chips. And the i remove the little sticker to be able to use it flat. After that i swapped the directions probably several times. Introducing a extr variable.
Sander, we should have known this much sooner!
1
XYZDesignPro 70
Here's a link to just about everything and anything you ever wanted to know about tempering glass:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&ved=2ahUKEwinwO21tIngAhUFN30KHbVTB8gQFjAJegQIAxAC&url=https%3A%2F%2Fbelglas.files.wordpress.com%2F2016%2F01%2Ftheglasstemperinghandbook.pdf&usg=AOvVaw0e6G55IzMoLKpjWmH-D9Zo
