There are a few other manufacturers who have 'dual color', which allows you to print with 2 different colors from the same material. For example, Builder has this feature with a Y conjunction above the hot end where both materials are fed in the same heaterblock. Usually this also results in only a horizontal (gradual) change of color.
Our goal is to enable dual extrusion, where you can print with 2 different materials. That is where the true potential and empowerment comes in play. Printing in multiple colors becomes interesting when you can go full color, having 2 colors available not that much.
16
10
8
6
Popular Days
Jan 26
14
Jan 29
11
Jan 27
9
Feb 7
9
SandervG 16 posts
ultiarjan 10 posts
Labern 8 posts
gr5 6 posts
Popular Days
Jan 26 2015
Jan 29 2015
Jan 27 2015
Feb 7 2015
Posted Images
zoev89 73
In the light of dual extrusion.
The cyclops hotend of E3D is an interesting design. It will eliminate the second nozzle problems. Of cause both materials must melt at the same temperature. It is still experimental so I guess E3D has not yet figured out how to use it well.
