A different multi-extrusion approach - UM tool / printhead changer
Posted (edited) · A different multi-extrusion approach - UM tool / printhead changer
I don't have much luck with the E3D ... finally found the energy to get the thing unclogged (which only worked by taking it apart and  by heating it up without the hot end cooling....) and started to put it back together again... securing the nozzle at 250c was not even putting a lot of force on it and the nozzle just broke of ... original E3D 0.4 nozzle....
Finally had some time to look at it again. I managed to save the block but had to damage the heat-break thread to get it out, after the heat-break was out i got the half nozzle out with the tool GR5 suggested. Already received spare parts, spend a shitload on E3D stuff so hopefully I'll get it working...
edit; ohh, and the E3D guy's told me i must have used too many force as there material would never fail :)but they gave me 18 pounds anyhow ... which is basically a heat-break + shipping..
    • Replies 1.3k
    • Created
    • Last Reply
    Posted Images
    Posted · A different multi-extrusion approach - UM tool / printhead changer
    Any luck with the e3d ultiarjan? I'm trying again, e3d sent me a new kit, and i got a spare heat break for the no.2 unit. I have updated my design to improve the cooling, and designed the second head to be height adjustable. So, the e3d....I have managed to print a robot, but whenever I try a longer print, I get a blockage still. Its super frustrating as i'm convinced the design is good. I am trying now with a different bowden tube (the other one i was trying had large ID). If that fails, the last thing i'll try before giving up, is a drop of oil in the bowden tube. I'm reluctant to do this as not sure if it will affect the strength of the prints. So close yet so far!
    I wonder why you'd prefer rails over shafts & linear bearings.
    I'm playing with the same idea, basically the H setup like in the Builder. I'm just still in doubt if I want to go for two motors/heads mounted on it (like the BCN sigma) or to stick with the magnetic mounts... I think I'll start playing with both ideas in CAD first.
    Even one week after finishing the strike German Post is not up-to-date with its delivery and so I'm still waiting for belts and pulleys. Otherwise I'd soon be able to report on a first test of the x/y gantry. I went for linear rails basically because I'm lazy (simply bolts on to laser cut metal parts) and many printer manufacturers use them as well.
    Have not jet had the time to test again, was planning to design a height adjustable mount this weekend but something came up and I wont be home all weekend... It will have to wait again...
    I was wondering about the retraction that seems to cause the pla to get stuck in the heat break, I can set the normal retraction to 2 mm, but we should probably also set the retraction at the end of a print (and tool change) very low ? Please let me know what you tried and your results...
    And I wonder if things get easier if we try with pet or XT ?
    Ok, so I don't want to jinx it, but I seem to have a working setup. I was tearing my hair out over it yesterday, and tried one last thing before giving up. The key seemed to be for me, adding a few drops of oil. I pulled the bowden out of the e3d, added two or three drops of oil, and put it back together. I've printed a couple of 2h plus prints so far, and not had a failure. To say i'm happy would be an understatement! This is with PLA by the way, can't see XT being a problem now either. I'll keep updating. Just printed my tool holder, not quite right so tweaked it a bit, and now printing again. Fingers crossed the e3d system is close to being complete! Nylon and PEEK prints coming up!!
    PS my retraction is also at 2mm
    Any problems with the larger retraction between prints? Can you do a cold pull pull / atomic? At what temp?
    I've not needed to do any atomic pulls, no blockages yet (fingers cross i won't get any more). Not sure on the retraction question...I daren't change anything now its working! I'll get the setup complete and working (with the two heads), then try adjusting reaction settings.
    So tonight I'm ready to do the repeat accuracy test with one head (park and resume). Can someone give me some instruction on how to edit the gcode? I know to do it in text edit with lookup and replace commands, but not sure where to insert etc. Also, how did you find the right coordinates for the head parking? From the ulticontroller? and finally, what is the 'F' command in the gcode before the XY coordinates?
    Thanks
    I can't help you with the important answers but "F" stands for feedrate and is in mm/minute so it is 60X larger than mm/sec. For example 50mm/sec is a F3000.
    It's the requested speed of ALL axes but since all moves are linear and E axis (extruder) moves the smallest amount the extruder rarely actually moves at the feedrate unless it is moving by itself.
    For a park and resume test I'd insert the gcode every layer change. There should be some comments in the generated gcode which indicate a new layer. And yes, I figured out the commands using the ulticontroller.
    I started by just trying with manual created Gcode, getting closer step by step, this was a pain ... I later did it by controlling the printer directy from Simplify3D, you can just enter lines of Gcode and the head moves directly. There are free alternative, I believe "pronterface" ? but I never used it..
    Also in Simplify3D you can automatically have the change code inserted into the code, I think I explained on around page 27 of this thread (if memory serves me well...).
    IM SO FRUSTRATED! So close, but i can't get this damn gcode right. So this is what I've written to test the head change accuracy, which works:
    ;LAYER
    G92 E0
    G1 E-2.5
    G92 E0
    G0 F9000 X100.000 Y180.000
    G0 F9000 Y192.7
    G0 F9000 X64.000
    G0 F3000 X16.000
    G0 F5000 Y100.000
    G0 F5000 X100.000 Y100.000
    G0 F5000 X16.000
    G0 F9000 Y180.000
    G0 F3000 Y192.700
    G0 F3000 X64.000
    G0 F9000 X100
    G1 F200 E2.5
    G92 E0
    ;FINISH
    So in the gcode, I did a look up for ';LAYER', and inserted the above. This works fine too. However when it uses the above code, after going back to the print, it does a huge rapid retraction, maybe 20-40mm or something, its crazy. I can't work out why its doing it, can anyone here help?
    This is the beginning few layers of the gcode :
    M190 S70.000000
    M109 S218.000000
    ;Sliced at: Mon 13-07-2015 17:37:18
    ;Basic settings: Layer height: 0.2 Walls: 0.4 Fill: 100
    ;Print time: 13 minutes
    ;Filament used: 0.305m 2.0g
    ;Filament cost: None
    ;M190 S70 ;Uncomment to add your own bed temperature line
    ;M109 S218 ;Uncomment to add your own temperature line
    G21 ;metric values
    G90 ;absolute positioning
    M82 ;set extruder to absolute mode
    M107 ;start with the fan off
    G28 X0 Y0 ;move X/Y to min endstops
    G28 Z0 ;move Z to min endstops
    G1 Z15.0 F9000 ;move the platform down 15mm
    G1 F200 E3 ;extrude 3mm of feed stock
    G92 E0 ;zero the extruded length again
    G1 F9000
    ;Put printing message on LCD screen
    M117 Printing...
    ;Layer count: 50
    ;LAYER
    G92 E0
    G1 E-2.5
    G92 E0
    G0 F9000 Y192.7
    G0 F9000 X64.000
    G0 F3000 X16.000
    G0 F5000 Y100.000
    G0 F5000 X16.000
    G0 F9000 Y180.000
    G0 F3000 Y192.700
    G0 F3000 X64.000
    G0 F9000 X100
    G1 F200 E2.5
    G92 E0
    ;FINISH0
    M107
    G0 F9000 X67.588 Y29.055 Z0.300
    ;TYPE:SKIRT
    G1 F1200 X85.228 Y29.055 E0.33182
    G1 X85.228 Y9.055 E0.70803
    G1 X92.128 Y9.055 E0.83782
    G1 X92.128 Y29.055 E1.21403
    G1 X105.727 Y29.055 E1.46984
    G1 X105.727 Y9.055 E1.84605
    G1 X112.627 Y9.055 E1.97584
    G1 X112.627 Y29.055 E2.35205
    G1 X132.627 Y29.055 E2.72826
    G1 X132.627 Y35.955 E2.85806
    G1 X112.627 Y35.955 E3.23427
    G1 X112.627 Y48.555 E3.47128
    G1 X132.627 Y48.555 E3.84749
    G1 X132.627 Y55.455 E3.97729
    G1 X112.627 Y55.455 E4.35350
    G1 X112.627 Y75.455 E4.72971
    G1 X105.727 Y75.455 E4.85950
    G1 X105.727 Y55.455 E5.23571
    G1 X92.128 Y55.455 E5.49152
    G1 X92.128 Y75.455 E5.86773
    G1 X85.228 Y75.455 E5.99752
    G1 X85.228 Y55.455 E6.37373
    G1 X67.588 Y55.455 E6.70555
    G1 X67.588 Y48.555 E6.83534
    G1 X85.228 Y48.555 E7.16716
    G1 X85.228 Y35.955 E7.40417
    G1 X67.588 Y35.955 E7.73599
    G1 X67.588 Y29.055 E7.86578
    G1 F2400 E5.86578
    G0 F9000 X70.988 Y32.455
    ;TYPE:WALL-OUTER
    G1 F2400 E7.86578
    G1 F1200 X88.628 Y32.455 E8.19760
    G1 X88.628 Y12.455 E8.57381
    G1 X88.728 Y12.455 E8.57570
    G1 X88.728 Y32.455 E8.95191
    G1 X109.127 Y32.455 E9.33562
    G1 X109.127 Y12.455 E9.71183
    G1 X109.227 Y12.455 E9.71371
    G1 X109.227 Y32.455 E10.08993
    G1 X129.227 Y32.455 E10.46614
    G1 X129.227 Y32.555 E10.46802
    G1 X109.227 Y32.555 E10.84423
    G1 X109.227 Y51.955 E11.20915
    G1 X129.227 Y51.955 E11.58537
    G1 X129.227 Y52.055 E11.58725
    G1 X109.227 Y52.055 E11.96346
    G1 X109.227 Y72.055 E12.33967
    G1 X109.127 Y72.055 E12.34155
    G1 X109.127 Y52.055 E12.71776
    G1 X88.728 Y52.055 E13.10148
    G1 X88.728 Y72.055 E13.47769
    G1 X88.628 Y72.055 E13.47957
    G1 X88.628 Y52.055 E13.85578
    G1 X70.988 Y52.055 E14.18760
    G1 X70.988 Y51.955 E14.18948
    G1 X88.628 Y51.955 E14.52130
    G1 X88.628 Y32.555 E14.88622
    G1 X70.988 Y32.555 E15.21804
    G1 X70.988 Y32.455 E15.21992
    G1 F2400 E13.21992
    G0 F9000 X88.728 Y32.555
    G1 F2400 E15.21992
    G1 F1200 X88.728 Y51.955 E15.58485
    G1 X109.127 Y51.955 E15.96856
    G1 X109.127 Y32.555 E16.33349
    G1 X88.728 Y32.555 E16.71720
    ;LAYER
    G92 E0
    G1 E-2.5
    G92 E0
    G0 F9000 Y192.7
    G0 F9000 X64.000
    G0 F3000 X16.000
    G0 F5000 Y100.000
    G0 F5000 X16.000
    G0 F9000 Y180.000
    G0 F3000 Y192.700
    G0 F3000 X64.000
    G0 F9000 X100
    G1 F200 E2.5
    G92 E0
    ;FINISH1
    M106 S153
    G0 F9000 X88.728 Y32.555 Z0.500
    ;TYPE:WALL-OUTER
    G1 F1320 X88.728 Y51.955 E16.96049
    G1 X109.127 Y51.955 E17.21630
    G1 X109.127 Y32.555 E17.45958
    G1 X88.728 Y32.555 E17.71539
    G0 F9000 X88.728 Y32.455
    G1 F1320 X109.127 Y32.455 E17.97120
    G1 X109.127 Y12.455 E18.22201
    G1 X109.227 Y12.455 E18.22327
    G1 X109.227 Y32.455 E18.47407
    G1 X129.227 Y32.455 E18.72488
    G1 X129.227 Y32.555 E18.72613
    G1 X109.227 Y32.555 E18.97694
    G1 X109.227 Y51.955 E19.22023
    G1 X129.227 Y51.955 E19.47103
    G1 X129.227 Y52.055 E19.47229
    G1 X109.227 Y52.055 E19.72309
    G1 X109.227 Y72.055 E19.97390
    G1 X109.127 Y72.055 E19.97516
    G1 X109.127 Y52.055 E20.22596
    G1 X88.728 Y52.055 E20.48177
    G1 X88.728 Y72.055 E20.73258
    G1 X88.628 Y72.055 E20.73384
    G1 X88.628 Y52.055 E20.98464
    G1 X70.988 Y52.055 E21.20586
    G1 X70.988 Y51.955 E21.20711
    G1 X88.628 Y51.955 E21.42832
    G1 X88.628 Y32.555 E21.67160
    G1 X70.988 Y32.555 E21.89282
    G1 X70.988 Y32.455 E21.89407
    G1 X88.628 Y32.455 E22.11528
    G1 X88.628 Y12.455 E22.36609
    G1 X88.728 Y12.455 E22.36734
    G1 X88.728 Y32.455 E22.61815
    ;LAYER
    G92 E0
    G1 E-2.5
    G92 E0
    G0 F9000 Y192.7
    G0 F9000 X64.000
    G0 F3000 X16.000
    G0 F5000 Y100.000
    G0 F5000 X16.000
    G0 F9000 Y180.000
    G0 F3000 Y192.700
    G0 F3000 X64.000
    G0 F9000 X100
    G1 F200 E2.5
    G92 E0
    ;FINISH2
    G0 F9000 X88.728 Y32.455 Z0.700
    ;TYPE:WALL-OUTER
    G1 F1500 X109.127 Y32.455 E22.87396
    G1 X109.127 Y12.455 E23.12477
    G1 X109.227 Y12.455 E23.12602
    G1 X109.227 Y32.455 E23.37683
    G1 X129.227 Y32.455 E23.62764
    G1 X129.227 Y32.555 E23.62889
    G1 X109.227 Y32.555 E23.87970
    G1 X109.227 Y51.955 E24.12298
    G1 X129.227 Y51.955 E24.37379
    G1 X129.227 Y52.055 E24.37505
    G1 X109.227 Y52.055 E24.62585
    G1 X109.227 Y72.055 E24.87666
    G1 X109.127 Y72.055 E24.87791
    G1 X109.127 Y52.055 E25.12872
    G1 X88.728 Y52.055 E25.38453
    G1 X88.728 Y72.055 E25.63534
    G1 X88.628 Y72.055 E25.63659
    G1 X88.628 Y52.055 E25.88740
    G1 X70.988 Y52.055 E26.10861
    G1 X70.988 Y51.955 E26.10987
    G1 X88.628 Y51.955 E26.33108
    G1 X88.628 Y32.555 E26.57436
    G1 X70.988 Y32.555 E26.79558
    G1 X70.988 Y32.455 E26.79683
    G1 X88.628 Y32.455 E27.01804
    G1 X88.628 Y12.455 E27.26885
    G1 X88.728 Y12.455 E27.27010
    G1 X88.728 Y32.455 E27.52091
    G1 F1500 X88.728 Y51.955 E27.76419
    G1 X109.127 Y51.955 E28.02000
    G1 X109.127 Y32.555 E28.26329
    G1 X88.728 Y32.555 E28.51910
    ;LAYER
    G92 E0
    G1 E-2.5
    G92 E0
    G0 F9000 Y192.7
    G0 F9000 X64.000
    G0 F3000 X16.000
    G0 F5000 Y100.000
    G0 F5000 X16.000
    G0 F9000 Y180.000
    G0 F3000 Y192.700
    G0 F3000 X64.000
    G0 F9000 X100
    G1 F200 E2.5
    G92 E0
    ;FINISH3
    G0 F9000 X88.728 Y32.555 Z0.900
    ;TYPE:WALL-OUTER
    G1 F1620 X88.728 Y51.955 E28.76238
    G1 X109.127 Y51.955 E29.01819
    G1 X109.127 Y32.555 E29.26148
    G1 X88.728 Y32.555 E29.51729
    G1 F1620 X109.127 Y32.455 E29.77310
    G1 X109.127 Y12.455 E30.02391
    G1 X109.227 Y12.455 E30.02516
    G1 X109.227 Y32.455 E30.27597
    G1 X129.227 Y32.455 E30.52677
    G1 X129.227 Y32.555 E30.52803
    G1 X109.227 Y32.555 E30.77884
    G1 X109.227 Y51.955 E31.02212
    G1 X129.227 Y51.955 E31.27293
    G1 X129.227 Y52.055 E31.27418
    G1 X109.227 Y52.055 E31.52499
    G1 X109.227 Y72.055 E31.77580
    G1 X109.127 Y72.055 E31.77705
    G1 X109.127 Y52.055 E32.02786
    G1 X88.728 Y52.055 E32.28367
    G1 X88.728 Y72.055 E32.53448
    G1 X88.628 Y72.055 E32.53573
    G1 X88.628 Y52.055 E32.78654
    G1 X70.988 Y52.055 E33.00775
    G1 X70.988 Y51.955 E33.00900
    G1 X88.628 Y51.955 E33.23022
    G1 X88.628 Y32.555 E33.47350
    G1 X70.988 Y32.555 E33.69471
    G1 X70.988 Y32.455 E33.69596
    G1 X88.628 Y32.455 E33.91718
    G1 X88.628 Y12.455 E34.16798
    G1 X88.728 Y12.455 E34.16924
    G1 X88.728 Y32.455 E34.42005
    If you read the info from ultiarjan or my pdf about how to insert the tool change I think you can get the picture of how to do it.
    Ok now I understand my mistake. It appears that the extrusion code is cumulative, so when it retracts for example by 2mm, it goes from 56mm (cumulative) to 54mm, then back to 56 after the X/Y steps have been completed. So the question is then, how on earth do you manually add retractions into gcode in cure?
    Here is extract showing this retraction in action:
    G1 X77.783 Y32.384 E7.86578
    G1 F2400 E5.86578
    G0 F9000 X81.183 Y35.784
    ;TYPE:WALL-OUTER
    G1 F2400 E7.86578
    Cheers I had a look at that, but i'm using cura and just for now want to manually add the code with retraction, that the bit i'm super struggers with.
    Cura has retraction for dual extruders at least the non-wipeout-style-new-beta
    also Simplify3D lets you specifically set the retract setting for toolchange
    Indeed simplify3d has everything to make this dual extrusion work. Specially since the last 3.0 version. I'm getting soo sweet prints. Well not sweet but nice since I have a banana rod :D but it does the job
    Wait a minute... if i get you right, this is just a test for your tool changer.
    You want to achieve a tool change on every layer (independent of any toolchange command).
    And you're looking for an easy way to integrate a retraction (without the need to struggle with the current E-position), right?
    My suggestions are:
    • you definitly don't want to zero the e-position between layers... :)- remove the "G92 E0" lines - that's the main source of your problem
    • if possible - remove the "G1 E..." commands too and use firmware retractions instead "G10" resp. "G11"
    • or switch on (temporary) relative positioning ("G91 G1 E-2.5 G90" resp. "G91 G1 E2.5 G90")
    This should do the trick.
    ;LAYER
    G10
    G0 F9000 Y192.7
    G0 F9000 X64.000
    G0 F3000 X16.000
    G0 F5000 Y100.000
    G0 F5000 X16.000
    G0 F9000 Y180.000
    G0 F3000 Y192.700
    G0 F3000 X64.000
    G0 F9000 X100
    G11
    ;FINISH
    ;LAYER
    G91
    G1 E-2.5
    G90
    G0 F9000 Y192.7
    G0 F9000 X64.000
    G0 F3000 X16.000
    G0 F5000 Y100.000
    G0 F5000 X16.000
    G0 F9000 Y180.000
    G0 F3000 Y192.700
    G0 F3000 X64.000
    G0 F9000 X100
    G91
    G1 F200 E2.5
    G90
    ;FINISH
    Feels more like slowprototyping the last weeks, but at least there's a little progress...
    The top & bottom part can slide a few mm for height adjustment, and fixed in place with the 2 screws. The E3D head is fixed in the bottom part, so fans always stay i at the same height vs the nozzle. Design is based on the original E3D fanholder (the .step is on thingiverse) I made it a bit stronger ;) and one side broke during mounting... XT is rather brittle... I'm starting to think more & more I should start printing ABS ...
    I just quickly drew the fanducts, actualy its version2, the first ones limited the airflow to much... curious to see how they will perform during printing..
    ...and one side broke during mounting... XT is rather brittle... I'm starting to think more & more I should start printing ABS ...
    I don't mean to offend, but the design IS kind of breakaway; doesn't really look like an issue with material properties. You could make those tabs a bit thicker. Turning them by 90 deg might not be a bad idea as well (not sure if there is enough space, though).
    ha ha, no offense taken at all...failure is just part of learning something..... but the tabs are not the issue, the side that clamps over the cooling ribs broke of as it's bending outwards during mounting.... I'm sure it would be no problem in PLA or ABS as it's a bit more flexibel, XT really is brittle.
    I did just rotate the tabs to be able to make the sides a bit thinner (to make them more flexible during mounting), but it also makes the mounting of screws easier. I'll try to do another print in XT tomorrow...
    Thanks for the suggestions guys. Tinkergnome, i'll give that a go tonight. I did try using the G10 G11 commands, but for some reason they didn't work. Does the gcode need a reference in it somewhere for the standard retract length at the beginning for it to work?
    All in all though, sounds like simplify3d is the way to go with this setup for full functionality, at least until Cura catches up (if the ultimaker team find these developments interesting enough). I'll start using simplify3d once i've confirmed the repeat accuracy.
    Ultiarjan, what settings are you using for XT? I found layer adhesion wasn't very good until I started to print around 248 degrees. But yea, its a little more brittle. However I've printed flexible clip on parts without issue.
    Uh ... I didn't see that. It looked like only half the tab was missing
    A quick photo of my (now tested and working!) setup with one extruder for now. I'm printing the height adjustable unit tonight which will sit on the back right of the machine.
        • 4 replies
