foehnsturm 969
"And now for something completely different."
- 8
Niceeee. You could also drill letters with awesome accuracy as second characters. Superb Foehnsturm!
Was not satisfied with the design nor the material, made 2 cuts in the design to allow it to flex more, and switched from XT to ABS. Although I had zero experience with ABS it went very well.
ABS printed at 250/100, 35 speed, 0.1 layer, closed front only, "cubestick" glue (sticks really good, almost to good as it's a pain to get the item of the glas..)
Edited by Guest"And now for something completely different."
Oh my gawd, the possibilities are endless!
Ultiarjan, was that Printed with simplify3d? Have you managed to properly set your print area and boundaries in that program? I wish I had as much luck printing abs...I always get it lifting off the bed.
Macua what problem do you have to set the boundaries? I mean you can't makr 'black' areas for the printer not to go to on any slicer (as far as I know) if that's what you want. On my works I just have a grid of the printing area for dual extruders and I just design the stuff knowing where can itnbe printed. I don't know if the new cura the 'autocenter' can be removed but on s3d the program loads the stls I make from rhino exactly on the same x/y/z so I just prepare the objects knowing where can or can't be printed.
Yea that's what I was hoping for. For standard umo, you can't place object too close to edges, as cura won't allow it. It knows the boundaries with reference to nozzle position. I'd like to do the same for this custom setup. Tell it that the front 40mm of bed are not part of printable area.
I'll just try changing the print bed size in cura, see what that does. Changing the home coordinates to negative i understand now, but not sure how to do it.
I'm roughly guessing my usable bedsize.
I should probably look into this again someday... I made a screenprint of the S3D bed and drew boundary lines on it... but I seem to have thrown it away cleaning up my desk ...
I redigned the hangers and made them smaller, full print area is now useable as the parked heads no longer interfere with the gantry. Also added a support/stiffener. Happy with this design now...although when I was printing it for the first time in a long time I got a blockage and under extrusion. Fixed now though...On to the dual extrusion tests!
The print looks like the heads need some x/y fine tuning, but promising!
Yup thats what the print is for. Adjusted already, on to a real print today.
So here is the first print. Excuse the missing left hand, the supper fell over at the beginning. This was printed with no wipe and prime tower, and no ooze shield. All I have done is remove the stringing. Pretty happy, although think would get far better results with the tower. Printed at 0.15, 60mm/s, no infill.
And the finished machine:
To do:
Sort the print area issue out
Re print small cartridge in fine resolution for better pickup accuracy.
Edited by GuestLooks great, good job!
I'm getting tired of the springs and I'm redesigning the head holder (the upper part) to remove the big m3 70mm screws and make the head adjustment much easier, also I wan't the possibilities of filament leak because the Hot end isolator coupler looses pressure and it 'tilts' if you adjust too light and filament goes through the peek down to the head (and it's a mess to clean).
So I'm doing this:
Also I'm going to print it on Formfutura Carbonfil, that can go to 85C without problems and not only it's very light it's really hard. Also it's great because you can print it without the bed on.
Neotko the adjustment will be Carried out by loosening the 4 bolts?
The material sounds interesting, looking forward to seeing the results. Looks like you are using 3 magnets? 3mm ones? And what about the locations cones, are you not using those?
Oh indeed the cones. I leave them hiden. It's the same yes. The magnets are the same ones. They are 1kilo force each, that I didn't touch since it works.
Indeed the idea it's to have 4 m3 5mm or 1mm to hold the lower part to the upper. Yesterday night printed the beta and seems to work so I'll print the new head this week and run some tests. Also I want to install the stainless steel fan cap.
Anyway I still have 2 umo+ to assemble so I might move slow this summer
Edited by GuestTwo more!? What for?
I'm closing a deal and if everything goes right I'll be printing 24/7 for a long time. Also I'm preparing a shop to sell some designed stuff. That's why lately I have not touch the design, but I need a better two extruder setup, and the leaks that can happen with the springs are a no-no.
I'm preparing a third version of my design, redesigning almost everything, but this one I want to make it on laser cut wood or print it on stainless steel, I did check some numbers and isn't super expensive, a main changer and 2 heads would cost around 80€ printed. Anyway that will take more sundays since it's the only day left for designs.
Wow sounds interesting, share the details when you can.
For any of you guys who would like a e3d v6 versions, which I now know works, the stl files are all here: https://www.youmagine.com/designs/e3d-v6-modular-print-system-magnetic-final
A brief description with gcode etc. Ill share some more pics of prints as they happen. If anyone else figures out the print area, and can give me some instructions please do!
What tip for the Merlin are you using there?
Also, I have found that the Merlin tip is very sensitive to crossflow fan airflow during the first millimeter of the print. Have you noticed this and if so, what work around have you used.
Top Posters In This Topic
280
228
170
133
Popular Days
Jul 14
22
Mar 26
19
Feb 13
18
Sep 23
17
foehnsturm 280 posts
neotko 228 posts
ultiarjan 170 posts
macua85 133 posts
Popular Days
Jul 14 2015
Mar 26 2015
Feb 13 2015
Sep 23 2015
Posted Images
macua85 52
Damn, that's all sounding a little over my head. Is it simpler to set these kind of settings in Simplify3d?
