Hey Murphy
I noticed you're not using the latest build. The newest build has a bit clearer GUI as to how the inheritance stuff works. In this case when you explicitly tell the fan to be at 10%, disabling the fan will never override that 10% value.
Material supports every setting you want.
69
13
13
10
Popular Days
Sep 4
15
Sep 22
14
Mar 12
10
Sep 10
9
nallath 69 posts
peggyb 13 posts
ultiarjan 13 posts
ahoeben 10 posts
Popular Days
Sep 4 2015
Sep 22 2015
Mar 12 2016
Sep 10 2015
Posted Images
Murphy 1
More feedback, about cooling:
When I uncheck 'Enable Cooling Fan' I still have some M106 in the gcode, that apparently ramps the fan towards 'Fan Full on at Layer', which takes the 'Minimum Fan Speed' value.
- if the "Enable Cooling Fan" is unchecked I expect the fan to stay off during the whole print (no M106).
It seems this checkbox value is not used (fan always on).
- if I set "Fan Full on at Layer" X, I expect it to use "Maximum Fan Speed" at layer X.
It seems to be using "Minimum Fan Speed".
The only way I found to completely disable the fan (without post processing the gcode) was to set "Minimum Fan Speed" to 0.
Also is it possible to tweak the Material settings in user space (currently in Cura.app/.../profiles/materials/)?
And what exactly does this support? Just temperatures or any setting?
I noticed the layer by layer view is very slow, in stable Cura it was slow just once, then we could move through the layers, now it's slow for each layer.
As a positive note, I love the new support patterns (which need docs in the mouse hover) and roof support!
Great work! I can't wait until next beta!
