kmanstudios 1,120
I still want the dilithium crystal power supply for off grid printing....
1
4 minutes ago, nallath said:Because every single profile would need to be changed and re-tested.
I know it is one more parameter, but at least the temperature is controlled instead of now depending of the room temperature, wind, humidity, etc.... Much more stable environment.
By the way this is why we have interns....
36 minutes ago, nallath said:Because every single profile would need to be changed and re-tested.
True! That's how you stay ahead!
17 hours ago, Swissengineer said:I know it is one more parameter, but at least the temperature is controlled instead of now depending of the room temperature, wind, humidity, etc.... Much more stable environment.
It's not just one parameter. All of them influence eachother. Just changing the temperature tends to be insufficient. It's something you can do by interns, but that's also not the way to stay ahead. I'd much prefer that our experienced process engineers do the profiles
On 4/1/2018 at 5:31 PM, FaultyTowels said:RGB all the things
Random Generation of Blobs?
I think that would be possible
1 minute ago, Marco_TvM said:Random Generation of Blobs?
Well, since we are wishing, I will repeat, give me a reason not to lust after a MarkForged. Either the ability to lay continuous fibre or at least reliably inset a CF plate and seal it (note - by 'sealing' I mean laying a border of filament to take up any space between the inset stiffener and the surrounding material)
J
I'd look into having the option for the user to mount the material on the side with the extruder towards the front. making it easier to load the material. have a heated enclosure as part of the machine. have a way to open the extruder for easy access for cleaning the feeder wheel whithout having to unscrew the whole thing. Four point bed levelling instead of the three currently used.
Make the front frame a bit wider making it easier to take out the glass plate.
Add a rubber mat, removable floor inside the printer making it easier to clean out the bottom of the printer.
just a few ideas
Why would you want four point leveling as 3 points define a plane? To have an overdefined system in order to reduce errors?
I'll just leave this post here... (big news!)
Yeeeeaaahhh finally !! So I see a much bigger print area, same print core system as UM3, I see doors ! and new HMI!!!! I think touch screen, with no buttons. Sadly it seems there is no top cover.
what do you means this?
How about make direct extruder version?
9 hours ago, ksmilejun said:what do you means this?
That's a mystery, you find more speculations at this post:
and this seems to be the release date:
Top Posters In This Topic
22
8
8
7
Popular Days
Nov 14
12
Jan 31
9
Nov 17
8
Mar 28
8
kmanstudios 22 posts
SandervG 8 posts
Swissengineer 8 posts
Labern 7 posts
Popular Days
Nov 14 2017
Jan 31 2018
Nov 17 2017
Mar 28 2018
Popular Posts
Swissengineer
Are you sure your problems are with the printer? or the interface between the chair and computer....
kmanstudios
Dear UltiSanta, I have been a good boy this year and would like to see the following things on an Ultimaker 4 system: Larger build volume because, well, I like big things and I cannot lie,
Labern
Option of a bigger build volume. New silent step control board with more smarts. Closed-loop stepper-motor control with step-loss compensation. Light weight direct drive. 5 extruders, system l
Posted Images
nallath 1,104
