More of a feature request than an answer: I want a printer that is bigger on the inside!
(Printing on an U2Go today:)
I heard a rumor it's really good at toasting bread and you can schedule it to be ready for breakfast in the morning.
The cores can spread whatever topping you want.
All I would like from a new printer is better quality at a faster print speed for a lower price...
Perhaps it should use quality components instead of poor cinese's ones and be assembled by technician instead that by monkeys?
That's would be a GREAT improvements !!
dude, stop being a dick.
you're only posting flamebait and you're being a troll.
the UM uses Misumi components which are japanese and not "poor cinese"
I'm sure that every now and then there are mistakes made when assembling the printers. that happens in every company.
what is the point you are trying to make and can you base it on an actual fact?
and actual fact is that UM scores very high with their printers in their userbase according to the yearly 3D Hubs survey..
I hope i will finally throw lasers *pew pew*
Get rid of arduino please. UM4 needs 32 bit motion planner. Keep the dual computers though -that part I hope continues into the UM4 design.
a closed chamber thermally regulated, with closed compartments for filaments like pva....
To be able to print cookies!?
Except the new BB-Q core - that one is only for summer dishes served outside.
that's already work - place some pancake dought at the build plate and give it some heat... :-)
That's baking cookies... I'm talking
So first layers of dough, then layers of niceness and finally some icing
So first layers of dough, then layers of niceness and finally some icing.
With all the cookie hungry people here at the office, I think we need a few of those printing 24/7
a faster and bigger volume option;
direct drive or bondtech feeder;
enclosured;
open-source since the beggining;
no micro stepping;
lasers and sensors everywhere...
8)
I really hope,
a joint-venture between Ultimaker and Olson
for an AA ruby core.
I really hope,
3dsolex.com has ruby cores.
no micro stepping;
What? No microstepping?
If you take away the 16X microstepping and want the same positional accuracy you would have to add a 16X gearbox. Also I'm not sure if the steppers can run 16X faster - they would need to handle 40,000 steps per second to hit 300mm/sec.
I know this is only a wish list....but please make something that can print large
Could care less about dual extruders (make it an option?)
The Olsson block and ability to use many filament types with no hassle....like the UM2+....
But could you afford it
The challenge is on them to put something on the market at a good price point
This, plus:
- Filament that is easily accessible - accessing from the back is a joke
- Firmware that doesn't glitch 24/7
- Cura that actually works quickly and reliably
I bought an UM3 for its reputation for reliability and quality - I mistakenly thought it would be 'print and go' - I've had nothing but problems. At the moment I can't even send a Simplify 3D print via Cura to the printer (using Simplify 3D because Cura is awful). The supported underside of prints are a complete mess, stringy and not flat. I should be able to just print it out of the box perfectly and only mess with settings if I want to - not have to change things because they don't work in the first place!
Top Posters In This Topic
22
8
8
7
Popular Days
Nov 14
12
Jan 31
9
Nov 17
8
Mar 28
8
kmanstudios 22 posts
Swissengineer 8 posts
SandervG 8 posts
Labern 7 posts
Popular Days
Nov 14 2017
Jan 31 2018
Nov 17 2017
Mar 28 2018
Popular Posts
Swissengineer
Are you sure your problems are with the printer? or the interface between the chair and computer....
SandervG
I'll just leave this post here... (big news!)
kmanstudios
Dear UltiSanta, I have been a good boy this year and would like to see the following things on an Ultimaker 4 system: Larger build volume because, well, I like big things and I cannot lie,
Posted Images
SandervG 1,407
Interesting question! I'll grab the popcorn
Thor666 5
mastory 42
Thor,
Did you build your own?
SandervG 1,407
