54 minutes ago, SandervG said:
Rumors, thoughts and comments are welcome!
Hello
I have just bought an Ultimker 3. Should I tell them to wait? When is this new one becoming available?
Hello
Will it print tiny parts better? Will you take a trade-in for a barely used 3 Extended?
I do like the new screws
13 minutes ago, Fulv said:Hello
You might! I can't tell you when it will be released, but if you look at our previous teasers, it was never very far from the actual release.
I'm sure if you talk to your reseller you can come to an agreement (like put it on hold until the release and then decide).
Hi Thank you for you reply.
will it be more expensive? Better than the Ultimaker 3 or just different or bigger?
@Fulv - keep in mind it might not meet your requirements. For example, it might not be able to print PLA. or it might cost a million euros. But it does appear to be a dual filament printer like the Ultimaker 3.
2 minutes ago, Fulv said:Hi Thank you for you reply.
No problem! I guess this is where we realize we've only launched a teaser.. these answers will require some more patience. Sorry
8 minutes ago, Coalwater said:Will it print tiny parts better? Will you take a trade-in for a barely used 3 Extended?
We don't (we don't do direct sales anymore) but if you want, you might want to check if your reseller offers something like that
28 minutes ago, SandervG said:We don't (we don't do direct sales anymore) but if you want, you might want to check if your reseller offers something like that
Yes, of course! I wasn't being too serious about that, I love my 3. But mow I will want the new one too!!
Thanks!
Yay, the Guessing Game is on! Let's analyze every pixel of every frame to try and discover what we're going to be told in a few weeks! And we can do it in 4k!
So, let's get the obvious out of the way:
- It's obviously a dual-core printer,
- Same way to get the spools on the back of the machine, but no protection for the spools shown,
- Looks like it uses the same printcores as the UM3/E
On to the changes:
- It has a front door that opens on both sides, and it looks like it uses big magnets to stick to the upper frame,
- It is definitely wider and cube-shaped, so, I'd say the print volume is up to 30*30*30, maybe 40*40*40. (I haven't gone as far as measuring pixels from stills! )
- Looks like a big touchscreen to replace the small display and the selection wheel, which is welcome news.
- No dilithium-powered energy matrix, I am disappointed.
8 minutes ago, Brulti said:- No dilithium-powered energy matrix, I am disappointed.
Problem was that dilithium was very difficult with legislation, being an accidental space-time warp risk. So we removed that feature last second.
Will you be bringing it to Rapid + TCT in Ft. Worth next week??!!!
it seems that you have swapped the 6mm shafts with the sturdier 8mm ones
and the short belts have different sized pulleys, something like 16/32 teeth?
27 minutes ago, Daid said:Problem was that dilithium was very difficult with legislation, being an accidental space-time warp risk. So we removed that feature last second.
Awwwww
38 minutes ago, Daid said:Problem was that dilithium was very difficult with legislation, being an accidental space-time warp risk. So we removed that feature last second.
So you must have quite some dilithium left... offer please...
Some guy in a DeLorean came by and bought all of it. He seemed in quite a hurry. Sorry.
SandervG 1,521
I dunno, some kind of hot plate seems more likely..
cjs 34
Seems do be quite a big hot plate.
Maybe Ultimaker is releasing a Pro Sous Vide Cooking machine
ahoeben 1,948
Looks like a dishwasher to me...
KevBell 0
Should I be returning my new CR-10 S5?
