tinkergnome 926
3 hours ago, foehnsturm said:@tinkergnome, I believe incoming signals on A won't generate interrupts when the flow sensor is disabled?
@conny_g - i guess you are using your own customized firmware anyway...? Just contact me, if you want to merge both versions, it should be easy with your expertise.
foehnsturm 969
Yep, it does but you have to print different adapter. @rigs is already testing it with a Bondtech.
