Gets stuck was a bad choice of word. The rollers stop turning, but filament continues to pass. As mentioned in the first part of that last post.
- 1 month later...
foehnsturm 970
So now it's:
@deisengard (3 units)
Almost a reasonable number. However due to holiday season here the new estimated shipping would be late August.
On 7/16/2019 at 5:17 PM, foehnsturm said:So now it's:
Don't forget about me 😉 (I already sent you a pm)!
- 1 month later...
Count me in UM2+
- 3 weeks later...
On 7/16/2019 at 11:17 AM, foehnsturm said:So now it's:
Any updates on this? I would still like to get 3 of these, and maybe even a 4th or 5th because i plan on getting a few more um2+'s in the near future.
- 3 weeks later...
Well this is a very interesting topic, but while reading this I lost track of the development progress for the UM3 version of the sensor, does anybody have an update?
Maybe now that the S3 is released (and the UM3, S5 and S3 run on the same code base) it would be a bit easier to implement the sensor for the UM3 since there is already a woring implementation for the S line printers.
- 2 weeks later...
On 9/13/2019 at 10:58 AM, Scrat82 said:Any updates on this? I would still like to get 3 of these, and maybe even a 4th or 5th because i plan on getting a few more um2+'s in the near future.
I'm also wondering about any updates on this... How many orders would you need in order to move forward? Thanks!
- 1 month later...
... same for me. I´ m running a Um3e and I´ m wondering if there is any progress to get an implementation of a sensor that comunicates with the hardwäre of my printer. Especcially because that would render my recent topic useless and would save me alot of braincells for solutions that are already in the makeing or about to get finalized...
If something however gets in the devstate of testing (UM3e only) pls count me in for it.
Thx.
- 2 weeks later...
Hello,
I'm also interested in.
I'm using UM2+ with dual extrusion, so I need two of the sensors.
How much does the package cost. Which firmware version do I need for the dual extrusion.
Regards
Ralf
- 2 months later...
Hi All. Also interested. UM3 extended. Very interested indeed!
I now have 5 um2+ machines that I really need filament monitors on each one. I am going to reach out to you to see if your still going to do this or not. Other wise I will find a different way to get this done on my machines.
I'm interested in this as well. Would likely need two since my UM2+ is a dual extruder.
- 4 weeks later...
Has anyone used the flow sensor with Cura 4.5? If I only set to print with Extruder 1 and turn off Extruder 2, Extruder 2 will still warm up to printing temp and continue to be in standby mode. The flow sensor will work no problem.
Normally if I print with one extruder, I would use the Ultimaker 2+ Machine settings. Using version 3.2.1, I can select Ultimaker 2+ and everything will print without a problem.
If I do the same using Cura 4.5, the flow sensor will work during the priming and then when it begins printing, the sensor will detect a material transport issue.
How is everyone printing with one extruder using 4.5?
Edited by henry-tong- 1 month later...
@foehnsturm
Is this project dead?
There seems to be enough interest, but no response...
With the S3 out now does this change anything? I am still interested in one for my Ultimaker 3.
Dim3nsioneer 559
On 5/14/2020 at 10:08 PM, Frogger said:With the S3 out now does this change anything? I am still interested in one for my Ultimaker 3.
Apart from the S3 having filament sensors (so there is now a printer with smaller build size and filament sensor) it does not change anything for the previous models. The firmware of the Ultimaker 3 and the S-line remains partially closed (means only the Marlin part is available upon request). That said it is not possible to adapt the Ultimaker 3 firmware and publish it legally.
On 5/14/2020 at 7:57 PM, reprogue said:There seems to be enough interest, but no response...
Afaik that interest was never large enough to make a small series production worth to be ramped up.
I would consider the project to be silently terminated.
If the project is terminated is there any chance to get the the information how to DIY the kit?
I have an S3 but also an old UM2+ and don't want to sell it as it prints so much faster and nicer because of the lighter head, but the flow sensor presented here would put it on another level… I really want one!
Not exactly what you asked for, but JFYI:
www.ibrieger.de/pimped-ultimaker-2.html#feeder-flowratesensor
On 5/16/2020 at 3:15 PM, Dim3nsioneer said:Afaik that interest was never large enough to make a small series production worth to be ramped up.
Doubtful, because foehnsturm mentioned in a post he needed at least 5 binding orders.
Looking at this thread, I count at least 10:
@Nomo
@gr5
@Scrat82
@scenic01
@rawafn (1 or 2 units)
@dfrez (1 or 2 units)
@reprogue
@Frogger
@AndrejV
@HaryPlotter (for UM3)
@wtfastro (for UM3)
foehnsturm hasn't been very talkative, so it's everyone's guess what's going on with this.
Too bad this isn't continued.
Dim3nsioneer 559
2 hours ago, reprogue said:Doubtful, because foehnsturm mentioned in a post he needed at least 5 binding orders.
The 5 binding orders were for testing the sensor at the start of the project. I refered to a small series production of something like 100-150 pcs.
His last post was an answer for 6 orders:
After first initial prototypes a 100-150pcs next order is a bit unrealistic… So probably something changed his mind, or he does not own a UM2 anymore and lost interest… I think it still would be nice if he did lost interest to give the BOM and source files, so somebody else can continue… It is clear that S3 already has the sensor and UM3 is closed firmware but there are still quite some UM2, UM2+ printers in operation out there that would greatly benefit from it...
Would be in with one too
BR
Luchador
Top Posters In This Topic
41
9
9
8
Popular Days
Jun 27
12
Jul 17
11
Jun 28
9
Jul 16
8
foehnsturm 41 posts
Dim3nsioneer 9 posts
conny_g 9 posts
3dprntz 8 posts
Popular Days
Jun 27 2018
Jul 17 2018
Jun 28 2018
Jul 16 2018
Popular Posts
foehnsturm
This is a project by a group of community members which was also involved in the Mark2 dual extrusion upgrade. More precisely, it's me coming up with an outside the box approach / weird idea for
rigs
First, thank @foehnsturm ( and all ) for this development work, now we will never be blind again I print 1/2 kg parts every day and have always wondered "why is the weight lighter than the weight
Posted Images
foehnsturm 970
With "gets stuck" do you mean the filament can't be moved anymore or the filament keeps moving but the sensor gear doesn't turn (sensor wheels slipping)?
