Hmm 240 for pla.... I wonder when that will kick in... also remarkable that the pla sequence is not just going up...
@nallath ?
I dont quite know what you mean by this..
I think @UltiArjan is referring to the fact that the other temps stay the same in all options, but the PLA temp goes from 210-210-195 and then up.. so same same, down, up..
I am assuming it has everything to do with the firmware that it is using, where you select the material and the nozzle size.. i suppose you would be able to select a nozzle size and a temp would fit to that.. so it might be default nozze, then 0.4, 0.25, 0.6 0.8 .
nallath 1,120
