I can change those values on the CURA SETTINGS....
will it work?
Yes, that would be good to do if you move the nozzle over. But those numbers are only used if you are printing multiple objects in "one at a time" mode. That makes sure the head doesn't hit the previously printed object while printing the next object.
GR5: Sadly, the model is not placed on the middle of the printing area...
110
109
71
62
Popular Days
Aug 18
22
Feb 19
22
Feb 20
19
Jan 24
19
swordriff 110 posts
gr5 109 posts
ultiarjan 71 posts
Anders Olsson 62 posts
Popular Days
Aug 18 2015
Feb 19 2015
Feb 20 2015
Jan 24 2015
Posted Images
swordriff 119
Less fluctuations with 35W heater.
When you reduce temp after 1st layer for instance, the temp
does not drop so far below your new target since the 40% harder heater
kicks in harder.
On the upside there is no such effect.
Edited by GuestLink to post
