Oh right. Thanks @gr5. So you're saying if a repeating layer banding problem were to be caused by the z screw, it should be at least 3 times the distance between each of the banding lines seen on my prints?
Any ideas what might be causing it then? Or is this typical of um2+ prints for whatever reasons?
Thanks again!
50
38
38
38
Popular Days
Jun 17
24
Jun 18
22
Jun 15
18
May 27
16
DrR1pper 50 posts
gr5 38 posts
cloakfiend 38 posts
Torgeir 38 posts
Popular Days
Jun 17 2015
Jun 18 2015
Jun 15 2015
May 27 2016
Popular Posts
gr5
Not so fast Martijn! This is not solved yet! I looked at the gcodes for the lines that get those diagonal lines on benchy. To the left of the arch (near the top of the arch) a typical movement in X
JohnInOttawa
This is of interest to me, I have both an Ultimaker Original and UM3, will certainly mod the Original, just need to decide if I will mod the UM3 as well. Shout out to gr5 - great service,
ArrMack
Hi, the link to this is dead. Any chance you could add an updated link?
Posted Images
gr5 2,194
The Z screw is triple helix. So it goes down 3 "bumps" for every rotation. So it seems most likely that this is a coincidence. For example if the Z screw was warped in the shape of a "C" I would expect patterns to repeat once every 3 bumps on the z screw - not every bump. But maybe I didn't think of something.
