hello
with version 4.4 of cura whatever extrude that I select it is always extrude 1 which prints
merci
hello
merci
22 hours ago, Anzen said:whatever extrude that I select it is always extrude 1 which prints
Can you elaborate a bit - what you're trying to achieve?
A (single material) print with the second extruder only will probably need a different start script.
Bonjour
merci pour votre intervention
j'utilise la version 3.6 de cura, perfectly works pour la sélection des extrudeuses
je prends la configuration avec la version cura 4.4 l'impression utilise toujours l'extrusion 1
avez-vous le même problème avec cura 4.4 et l'imprimante foehnsturm Mark2
Edited by AnzenWell, I'm not that familiar with Cura, but what i noticed is:
Cura always adds a toolchange command with the initial extruder number right at the beginning of the file - even before the start script. This does not work. The T1 command is needed "after" the start script.
(I don't know if former Cura versions handled it different).
I usually edit the gcode file manually if the print really needs to start with the second extruder.
It may be a possible workaround to add an additional tool-change command at the end of the start script, but i have not tried it yet.
G92 E0
T{adhesion_extruder_nr}
;end of startup sequence
I've searched the thread but couldn't find anything similar. But I've noticed when I'm doing ABS and HIPS prints with the bed at 100C, the printer struggles with keeping the bed up to temp, which leads to the print warping and then popping off. With a single nozzle print, I have no issues with adhesion and keeping the bed at 100C.
I currently have the top of the printer covered with an old printer paper box and the front covered with a plastic lid as a means to keep heat in.
The bed gets up to temp like normal when everything is heating up, but once the nozzles are turned on and the print starts, the bed starts to cool. Sounds like a power budget issue to me. I haven't had the printer shut off at all with my current settings of 175/150/40/40. So perhaps I need to increase the budget (1st number) a little more so that the printer isn't afraid to apply more power to the bed to keep it at temp?
I also saw an older post here about someone powering the bed with a separate PSU, which could be an option or replacing the 220W PSU with a 280W PSU. Both are options I suppose, but was wanted to see if there was a way to just make due with the current hardware.
16 hours ago, Torgeir said:
Hi Torgeir,
thank you for the info. Do you do abs prints with your mark2 as well? Also could you provide the PN on that Dell PSU? Might be cheaper to find than the MeanWell. I just can’t make out the number in the picture.
Hi dfrez,
This is Dell DA-2 Series
P/N: N112H
Model: D2950P-01
Just search google using: dell D2950P-01
This unit has the right type of connector, no extra work... 🙂
Good luck
Torgeir
Edited by TorgeirHey Guys,
I installed Cura 4.4.1 and I'm running the mark 2 extension software 19.03 but when my Print finished it does not home the head and does not lower the building plate either. So there will always remain a little dot at the end of a print.
Any thoughts how to fix that?
Thanks
Georg
4 hours ago, georgp said:when my Print finished it does not home the head and does not lower the building plate either
Hi Georg,
was the print started from the SD-card on the printer like common? The firmware should perform the finishing steps in this case...? 🤷♂️
Were the "cooling down" and "print finished" screens shown as usual?
Actually I was printing via USB connection. Could this be the issue?
And also the Fans on the sides seem not to work - just the main Fans is running when printing
Any thoughts on that?
Thanks for your help!
8 hours ago, georgp said:Actually I was printing via USB connection. Could this be the issue?
In this case you can add these steps to the end-script in Cura or to the according gcode script in the printing host (if applicable).
My "print finished" script in Octoprint looks like this:
(it's just an example, YMMV)
;disable all heaters
{% snippet 'disable_hotends' %}
{% snippet 'disable_bed' %}
;end retract
M302 S0
G90
G92 E11.0
G1 E0 F1500
M400
M302 S170
;reset settings
M501
;move to parking pos
T0
G0 X23 Y200 F10800
;G28 Z0
G0 Z200 F2000
; disable motors
M84
M117
8 hours ago, georgp said:And also the Fans on the sides seem not to work - just the main Fans is running when printing
I guess that's a different issue. You can test the fans in the "Advanced" menu.
Does it apply to both printheads?
Sorry for the late response by modifying the gcode just by adding T1 works correctly
Edited by Anzen
;disable all heaters {% snippet 'disable_hotends' %} {% snippet 'disable_bed' %} ;end retract M302 S0 G90 G92 E11.0 G1 E0 F1500 M400 M302 S170 ;reset settings M501 ;move to parking pos T0 G0 X23 Y200 F10800 ;G28 Z0 G0 Z200 F2000 ; disable motors M84 M117
Thanks!
I was using your end script and it is kinda doing what it should but it doesn't home the head and the building plate entirely so i still have to do that manually after a print. Is this also the case for you?
The fans seem to work now.
I also have another issue:
I want to print with different nozzles (also a 1.5 mm nozzle) but i cannot find the nozzle diameter in cura anymore and also there are no settings for 1.5 mm nozzles. Any ideas how to use it?
And any advice if i want to print with 2 different nozzle sizes?
Thank you so much!
Cheers
Georg
17 hours ago, georgp said:doesn't home the head and the building plate entirely so i still have to do that manually after a print. Is this also the case for you?
Yes, that's intended (on my side) - it's the ymmv-part of the example 🙂
You can change the last few movements if you prefer the actual "homing".
Like so:
T0
G0 X23 Y200 F10800
G28 X0 Y0 ;home head
G0 Z200 F2000
G28 Z0 ;home buildplate
; disable motors
M84
17 hours ago, georgp said:And any advice if i want to print with 2 different nozzle sizes?
I would choose the closest variant (a.k.a. nozzle size) per extruder and adjust the line width to the real size. Line width settings are the ones that count (make all of them visible first - there are quite a few).
Just an update to my earlier post, I played around with the power budget settings and now I'm able to print with both nozzles running and bed at 100C. 😀
I originally had it at a much "safer" setting of 140/170/40/40. Changed it to 180/150/35/35, which I believe is the default and it seems to be working well so far. For what it's worth, the PN of my power brick has "GS" and not "GST" which @gr5 has stated is more prone to shutting down.
Now I need to mess with the support material profile...
I thought I'd post another update as I've worked through a few issues specific to my use cases.
I've been doing lots of ABS prints in a hot enclosure (70C+), and it seems like my magnets are getting weaker, losing alignment or I don't know what. I was never able to reach the furthest corners without the head popping off but it got worse and worse.
I modified the head and the coupling to include an additional 4 magnets and printed everything over 11 hours with a 0.25mm nozzle in ABS (fusion+ from Innofil/BASF, it's pretty good!).
I also beefed up the coupling to also act as a spacer for the head assembly. What I was finding was that the original design Z height of the coupling was dependant on the top height of the plastic part of the head. And this varied depending on how tight the screws were etc. My modification (which is pig ugly) is captured in the metal part of the head assembly and so is more accurately set over time.
It is rock solid now, I think my magnets were crappy but now I've got 7 of them I think there is a nice safety factor.
Also just found a great trick using "terrain to STL" and switching the shell extruder to a different colour for contour lines.
One quick question for tinkergnome, why is it that you've set the maximum temp adjust to be + or - 25 in the Mark2 firmware but not in your normal UM2 firmware? Thanks again for the epic work everyone, I could never go back to a single extruder now.
12 hours ago, Whom said:One quick question for tinkergnome, why is it that you've set the maximum temp adjust to be + or - 25 in the Mark2 firmware but not in your normal UM2 firmware?
The switch to temperature offsets in the "tune" menu (instead of absolute values) was necessary because the gcode now contains a lot of temperature changes (for multi-extruder prints). I think there are four or five temperatures for each extruder in Cura.
Any absolute tuning value would be permanently overridden by the gcode and therefor pretty useless. The +/- 25C approach was more or less adopted from the brand new UM3 back then.
Just to be sure:
Do you miss the offsets in the old firmware or the absolute values for the Mark2?
BTW: Normal neodymium magnets are losing their magnetic effect irreversible above 80C.
But there are neodymium magnets with higher temperature grades available.
Just to be sure:
Ahh that makes sense, I really should have realised this. I miss the absolute value but only because as I switch back and forth between pla or abs if I forget to update the material settings in cura I can fix it when the print starts. But with the "temperature magic" I think you called it I understand why you switched to an offset. In a perfect world the offset limit could be more than 25 for the heated bed. Or I could just learn to check by slicing settings haha
80! Of course, that would have done it then. I was assuming all could manage 100+ like an RC motor but I'm pretty sure I hit 80 at least once in the enclosure. The enclosure I build was too well insulated, I've ordered some fans and control boards to make it regulated. I'll go teach myself about magnets and order some more.
Thank you! I hope nobody is offended by my ugly modifications haha
6 minutes ago, Whom said:I'll go teach myself about magnets and order some more.
I think these explanations about the various grades are pretty comprehensive:
https://www.supermagnete.de/eng/faq/What-temperatures-can-magnets-withstand
https://www.supermagnete.de/eng/physical-magnet-data
11 minutes ago, Whom said:I hope nobody is offended by my ugly modifications haha
I guess the mechanism is a bit over-constrained now.... but if it works... who cares? 🙂
Amazing, thank you. I've got some homework to do! I think I'm going to find some higher temp ones, perhaps a different shape and remodel the heads for my "heavy duty" needs.
Yeah I was worried about it no longer being a 'tripod'. But since I stiffened up the coupler with side bars it's basically two flat planes and since I used the head to set the position of the coupler magnets there doesn't seem to be any misalignment gaps (yet). But I'll keep an eye on it. I aligned the slots with the center of rotation so it drops into place nicely.
Hi there and thanks for your previous help.
I Have a new Issue.
I just wanted to print the entire print with heaed 2 because i do not always want to change nozzles but somehow it picks head 2 but then prints everything else with head 1 even if i select head 2 to print the entire object.
Any idea?
Thanks!
Edited by georgp
Top Posters In This Topic
90
81
70
66
Popular Days
May 5
30
Mar 24
25
May 4
23
May 6
22
RudydG 90 posts
foehnsturm 81 posts
tinkergnome 70 posts
ultiarjan 66 posts
Popular Days
May 5 2017
Mar 24 2020
May 4 2017
May 6 2017
Popular Posts
rigs
@zerspaner_gerd & @MarcoUbtz Thank you gentlemen, everything is working perfectly now https://www.youmagine.com/designs/flexible-coupler-using-colorfabb-ngen-flex
qwerty8224
correct please definition of nozzles for Сura 3.4 [values] machine_nozzle_size = 0.6 machine_nozzle_tip_outer_diameter = 1.25 coasting_volume = 1.36 speed_wall = = round (speed_print * 4/3, 1)
morfeushav
I am creating too a holder for mount the clamping dock on a ultimaker 2 aluminum clone. I haven´t have yet the final part., and I have to test it. This is how looks
Posted Images
only_36 0
@dfrez yes I have read you got the same kind of troubles. I have ordered new magnet from the recommanded shop as the first set was included in the cheap Mark2 kit from China. Electronic stuff is ok but I was not enough cautious with magnets quality.
Edited by only_36Link to post
