1 hour ago, DrZebra said:Hi there,
The new updates are nice, however I feel like I may have misunderstood something as I cant find these new cloud features, can I ask where they are?
If I launch cura connect its the same as before but with extra print info tracking.
I i press the "open ultimaker account" button, it takes me to a webpage where the only options are to log out, or enable two factor security.
Where are these new features? The ultimaker app on my phone still wont let me access my printer from outside the local network, despite the fact it is now showing my phone in cura connect.
"This lets you print from outside the realms of your local network with an Ultimaker 3 or Ultimaker S5 via your Ultimaker account. "
If you could direct me to this, that would be great, mostly all Im looking for is to be able to view and cancel prints via phone.
You can start the cloud connection flow from Cura Connect's settings page (http://IP_ADDRESS/settings). That'll guide you through the steps, eventually asking you to open op Cura for the final 'handshake'.
DrZebra 1
Hi there,
Edited by DrZebraIf I launch cura connect its the same as before but with extra print info tracking.
Digibike 69
I get the Information, that there is a new Firmware. So I had choose it and the Printer (UM3 E) will install it fine.
But now, he will never Print from USB? All Files, which will Print perfectly with the Firmware before, will get
the Information at start, that the Print will be finished in 0 h 0 min and 0 sec. The Printer will also don´t Print
the files.
What is wrong with it?
What can I do to correct it? I only Print from USB.
How can I roll back, if there is no Chance to corect it now? The Printer will only Show that the FW is the latest.
A factory-Reset don´t helped. The Problem is the same as before the factory-reset...
Hope, someone can help!
With regards, Digibike
