I'm one of the developers involved in Connect. As @Smithy indicates, ethernet will always be more stable than wifi. However we're still interested in finding potential problems that are unrelated to wireless technology. Maybe you could share the logs of your printer with us (in a private message if desired)? You can find the option to dump logs to USB in the printer's settings menu.
Also, which firmware version are you running?
Thanks!
Smithy 1,145
If you have the possibility to use the ethernet connection, then do it. For whatever reason the wifi connection is not as stable as it should, but with the wired ethernet it works fine and stable.
