Post your latest print!
IRobertI
Posted · Post your latest print!
@Wallan: fantastic pinup WIP, looks awesome! Hope that you soon will post some new stuff about it!
@Leo DDC i like the print with white PLA! Apart from that your prints are getting better;)
I think it is not the right thread for it but i try it anyway:) Did somebody already switched to direct drive with the Ulti Original? And those who did, are you satisfied?
Today i startet to get things done and did the first part for the left side. The second is on the run. I tried to make it small but in a way that everything is visible because I wanted to see the coupling moving. I like mashines! I will put a embedded damper between the stepper and the holder to not get to loud.
Dd left No render 1
Dd left No render 4
Dd left No render 3
It is not yet a print but i will try my best to bring you some fully assembled pics when everything is done.
Greetings
    No wonder the images are huge, you're using PNG... If you were to save those as JPEGs instead (even at high quality) they'd be a tenth as heavy to load and you wouldn't be able to tell the difference visually. Something to consider for next time ;)
    My latest print, I got some airbrush's and a compressor for my b-day so i am now going to try and paint some of my prints.... so this is my first test subject....
    T800
    Looks great! what paint are you using? that metalic paint seems more reflective than most.
    Cor3ys, I'm impressed by the quality of the surface, too. Nice coating. It comes close to the version by Adam Savage, and that one has real chromium coating. (I didn't know, that it is possible to chrome plastic until this video)
    The video is a nice reference.
    @cor3ys: Awesome work man!
    I was going to suggest going over it with some black paint but the video above saves the explanation, just watch that instead.
    "Tested" is a pretty sweet channel over at youtube for those that don't know. Adam Savage makes regular appearances and even Jamie sticks his head in from time to time.
    "...material is a lot rougher on the over hangs and noisy areas but it does seem to have a very slightly smoother surface in areas of low noise."
    Hi Leo,
    This topic is growing so fast I can't keep up :D I saw from the pictures you posted a few pages back you had some issues with overhangs. My best guess would be your printing the overhangs to fast so they don't have enough time to cool, you should be able to see this during print, the layer will curl upwards towards the nozzle.
    Instead of slowing down the entire print, which is an option, you could also increase the minimal layer time. The default setting is 5s, you could increase this to about 8s. Especially on small prints with overhangs this will make a difference in quality.
    Like your work, looks very cool and bit creapy :)
    cheers,
    Gijs
    Cor3ys, whoa man I didnt know you was working on a terminator. You, Braddock and I need to meet up for a beer soon, bring all out T800 parts and we should make a full terminator lol.
    Conz, great video link. Loved seeing the T800 arm, reminded me of my one which I should finish haha.
    The plating process which they refer to is standard " electro plating ". There is a series of dip baths, first copper, then nickel then the chromium plating on last. Dip bathing used to be done by hand ( still is in lots of places ) but big factories are all mechanised dipping booths now.
    ABS, which our lovely printers can print, is a great plastic for electroplating!!
    @valcrow i use Vallejo paints but the chrome spray was something called plastikote
    @leoDDC thank you..
    @iroberti thanks for the advice will check out tested
    @conz thanks for the link
    @skint yeh LOL
    speaking of which... almost finished modeling the first pate. The face plate. I'm rebuilding a scan from an actual endoskull. The scan isn't great, a lot of lost detail, so cross referencing with a Vinyl recast endoskull I have on my desk.
    I wont be modeling / printing teeth. This will be 1:1 so intend to use acrylic false teeth.
    face 01
    Looking awesome so far, looking forward to the final product. I hope you haven't changed your mind on sharing it :D
    I'll share it only if people promise not to print it at anything less than 0.06mm
    Great, then I'll print it at 0.2 since that's more than 0.06 :D (sorry, couldn't resist :p )
    Maybe I'll only release GCode :)
    Hi all,
    Yesterday i finally upgraded the firmware of my UM2 and i couldn't resist playing with the new pause function
    20140507 072735
    I don't know if this is recommended but this is what i did:
    I do think that this is easier (maybe only possible) with Robert's great feeder design.
    Pause the print
    Reduce the hotend temp to 90°c
    Release the pressure in the feeder with the clip
    Pull out the filament by hand
    Push the other filament by hand until it stops
    Put temp back to 210°c
    Push filament by hand to extrude a bit
    Reclip the feeder to make it work again
    Resume print
    I've wanted to try this for a couple of weeks just for fun :)
    Next new attempt at the UM Robot, it's now near to perfect i think
    20140507 072749
    20140507 072757
    20140507 072815
    Last, first attempts to braddock's awesome design
    Layer height of 0.08 i think
    Had to abort the print before it finished because of a thunder storm approaching :mrgreen:
    20140507 072844
    20140507 072852
    Mostly ok except for this:
    20140507 072906
    I will start a separate thread for this issue
    Well nothing as awesome as those T800 heads (because my modeling skills just suck so far).
    More RC boat stuff: just a simple wheelhouse for my springer towboat.
    The real deal looks like this, super easy to model:
    Truckable tug
    My model in SketchUp (still haven't tried Autodesk Fusion 360!):
    Wheelhouse 3D model
    Wheelhouse 3D model
    First print failed due to a clogged nozzle. And I'm still not in the clear ...
    For the second print attempt I decided to try meshmixer's support generator instead of Cura (Cura's scaffolding works quite great but is also heavy handed)
    Meshmixer-generated support
    My nozzle is probably still partially clogged or has some left over gunk because filament tends to curl like crazy.
    Some of the support failed to print yet the support that managed to get printed did the job and just snapped off clean. Quite impressed with meshmixer (though I still struggle with its UI).
    Anyway, that's what I got after 23 hours (wheelhouse, door, bridge) + 6 hours (roof, navlight brackets). Might have been able to print everything at once but I still had some work to do on the roof.
    Roof just fits snugly in the wheelhouse. Won't have to glue it in place so that I can reach the inside of the wheelhouse for "maintenance"
    Front view
    Working hinges
    Rear view
    All the parts
    Now I need to clean up the nozzle real good to get the printer working 100% before I move to ABS ...
    @ braddock. That looks ace!! If you need any help with the modelling let me know, although I am on Creo. Cant wait to see some of this.
    @Didier. Oh thanks for the reminder on the Pause button. I have a bad habbit of playing with prints whilst its still printing lol, pause will help me fiddle easier :p
    @Calimero. Really coming along nicely. That`s going to be an awesome model.
    i love this tread so much.. so many amazing new designs and creations and what I find totally brilliant is.. users are sitting down using different software and creating their own projects and not just downloading stuff off the net and clicking print..
    I know its not the first time I have complimented on this treat but i have to... :-)
    Ian :-)
    I knooooow. One of my most favorite threads.
    All the creativity is so inspiring!
    And the overal quality / expertise is sky-rocketing!!! :eek:
    @Didier: Nice prints. I had the same problem with the Ieyo model.
    I fixed it though by reducing the speed from 30mm/sec to 20mm/sec and turning up the minimum layer cool time to 10 seconds. I also lowered the temperature to 190. Its now printing and looks much better. I will post some pics soon.
    @Calimero: Nice model and the print looks nice and clean.
    @braddock: So excited to see the finished piece.
    Another job for an office furniture factory... The most challenging job so far! ;)
    That looks great! It's so very clean looking.
    The scale is kinda wonkey though, it looks tiny because of the DOF, but the print lines seem quite fine.
    Tilt shift?
    Wow! The mesh must have been crazy to print
    Stunning print Oswaldo !
