So its confirmed dead...hoping its only the arduino. Ive just ordered a replacement, should be here tomorrow. Fingers crossed all is ok after that!
Usually there are no melting fuses used in nowadays electronics. Only self-resetting stuff such as PTC fuses.
In 3D printer electronics, there are a few boards that have PTC fuses, but most of them don't and will simply blow out some component(s) when you create a short-circuit.
Thanks for giving me something that I have to check on with my own electronics project
Hey guys,
So I replaced the arduino, and can now upload firmware files no problem. However, the ulticontroller screen is blank, with the backlight cycling between 3 brightness levels continuously. I try to run bed level wizard from cura, but says can establish connection. Any idea what the cause is? Or what I could have fried on the ultimaker board?
Thought of this a long time ago, but finally made a proof of concept.
to setup the wipe shield on the bed you need to calculate the Z in every change. I don't think this is possible in S3D's scripting. Ideally I would write a post-processing script in python (to reuse as cura plugin) but learning python is still on the long to-do list, so I got creative a made a postprocessing template in ms-excel... a lot faster to use the tools you know
It may not show well in the video but I'm priming before the wipe.
I feel this could work, need to do a few more things;
- make a wipe container that actually holds the rubber, think I'll use small a alu L-profile
- make the wipe area wider, and vary the wipe position over the total length
- add a retract after the wipe
fyi, the red and white "ears" on both side of the printer are magnetic holders to park the heads outside the printer when needed..
Edited by Guest- 3
Video is private :/
should be solved now ...Video is private :/
One question. Have you tried to make an absolute positioning on the tool change and after that reseting the z to the right one using the [current_Z_position]?
Btw seems on v3 they changed the placeholder to [current_position_z]. With that for what I read on s3d forums you could totally do it automagically without the excel.
that would be nice... i'll have a look around there forum... thanksBtw seems on v3 they changed the placeholder to [current_position_z]. With that for what I read on s3d forums you could totally do it automagically without the excel.
There's a great example of a user that uses the command to wipe the extruder on their cube wipe box.
{IF NEWTOOL=0}T0{IF NEWTOOL=1}T1G1 X108.000 Y136.000 Z[current_Z_position] F8000.0G1 X108.000 Y161.000 Z[current_Z_position] F8000.0{IF NEWTOOL=0}M101REV{IF NEWTOOL=1}M201REVG1 X109.000 Y161.000 Z[current_Z_position] F8000.0G4 P5M103G1 X108.000 Y136.000 Z[current_Z_position] F8000.0G1 X108.000 Y161.000 Z[current_Z_position] F8000.0
Copy from: https://forum.simplify3d.com/viewtopic.php?f=8&t=2067&start=20 But I think they changed the name of current_Z_position for what I found reading other posts, but with that it should be a walk in the park to use your wipe box.
Just one think... I really really think you need aluminium to hold the peek. It's part of the original design to disipate the heat (100C) on that area. Upper bigger area of peek reaches 62C with aluminium down there so It should clog very fast. But I can't wait to read from you what you wrote.
Edited by GuestOh I see you attached the cooling fan. Umm interesting. Anyhow gou might need to 'curve' the inside so the fan air hits both sides of the peek.
Yup, the cooling fan seems to take care of it all. Ive printed an 8h 250 degree print with no issues. The cooling fan is ducted inside the unit to flow to underneath and the PTFE, pics show it better:
I did learn the hard way though. Accidentally unplugged one of the fans and started a print...the PEEK crapped itself out of the bottom of the assemble within 5 mins.
Edited by Guest- 2
foehnsturm 969
Haha, no i'm not that advanced! The third 'umbilical' is for the parts fan on the main gantry head
- 2
Time for an update. I've had a chance to run off the first proper dual extrusion print with the new setup. I have to say, i'm pretty pleased with the results. The parts cooling is still a bit of a work in progress, but I adapted my design to suit the position of the two different hotends. One of them sits in a different position due to the height adjustment mechanism.
First test print robot results look good, I think this design is a keeper. Its a print and forget system now the e3d and jamming has been removed from the equation. The one screw height adjustment is also working as expected, no issues levelling the nozzles, and it stays good once set.
Once again, at this moment i'd post pictures but the new website/forum is letting me down. I'll try again tomorrow.
Edited by GuestI'm very interested on seeing that one screw leveling solution. Mine it's too bulky and while it works I was going to change it for a 3mm flexible material part that could be compressed when screwing all. Anyhow I think since your heads don't touch the place when they are parked, you could juat make a z level change. S3D let's you assign z offsets for each process.
Ohh I get it now. That's a quite clean solution. Great!
KevinMakes 22
I have found that a better "wiping tool" is the cut off head of a small (toothbrush sized) wire brush.
I tryed that route and the problem I see on that it's that the filament sticks to it too much. I got trouble when the brush was too much 'fillup' causing the head to tild when hitting the cold pla.
I would love to have something like this to save space and it could be called by a gcode?
http://3dprint.com/87898/3d-printer-hacks/
Edited by Guest- 1
280
228
170
133
Popular Days
Jul 14
22
Mar 26
19
Feb 13
18
Sep 23
17
foehnsturm 280 posts
neotko 228 posts
ultiarjan 170 posts
macua85 133 posts
Popular Days
Jul 14 2015
Mar 26 2015
Feb 13 2015
Sep 23 2015
Posted Images
macua85 52
So, i have tried disconnecting heaters etc, no change. I removed the steppers, and now I am able to turn it on, even after the steppers are back in. However, the ulticontroller is coming up blank, (or a few half blocks showing), and the USB doesn't communicate with the laptop, no connection. So think i've fried the arduino? Maybe thats where the click came from? DO they have any fuses?
I'll give up for the night now, and see if its working in the morning but I have my doubts. Its ironic, I've managed to fix the fan which caused all these problems in the first place!
