Anyone thought of creating a side purge bucket?
On 12/1/2020 at 4:58 AM, Garufa said:
Basically, I don't understand how your design work, but my design is try to not modify the metal parts, because they can help to hold the extruder in position and only allow it move up and down.
7 hours ago, Benleo888 said:Basically, I don't understand how your design work, but my design is try to not modify the metal parts, because they can help to hold the extruder in position and only allow it move up and down.
I hope this images can explain it better, sorry for not having more details before
@Garufa, @nvcheeko, @Benleo888
Sorry for that I repeat my question, but do all of you use 1.75mm filament?
Where can I find Hotends for 2.85mm or is there a description to modify the hotends?
Thanks for your help
4 hours ago, jtronics said:@Garufa, @nvcheeko, @Benleo888
1.75 only in my case. option you have is to install an UM3 head and always first pre-heat nozzle 2 on your start Gcode
Hi
Trying to learn about this mod :)
Are the changes to the metals parts I see mentioned in the thread needed for me to modify my UM2+ into DXU?
Or what are they actually needed for?
Thanks
On 12/7/2020 at 8:39 AM, X-Type said:Hi
Trying to learn about this mod 🙂
Thanks
If you arr talking about the mod I post before, the anwser is yes, mainly the metal heatsink for second extruder. However, for original UM2+, these extruder design with heatsink is already modify version and mainly for 1.75mm filament.
- 2 weeks later...
Hi guys!
I do really like this project!
Because of this project I started building a Ultimaker 2 extended.
But I was wondering, is there somebody out there thats is using the E3D V6 hotends?
I don`'t really understand the ones off ultimaker.
I have orderd two of them, but I now see i need more than just that. I also need those metal plates of the printhead: Printhead parts
Thanks!
- 3 weeks later...
On 12/21/2020 at 8:11 PM, stefan787 said:Hi guys!
Thanks!
Are there specific E3D V6 hotends for Ultimaker?
Is it possible to run higher temps with those?
On 7/21/2020 at 9:43 PM, alexjx said:I am.
Can you please share the firmware changes for the Duet to work with the DXU?
- 2 weeks later...
Ciao @yyh1002 I have inaccurate values in the temperature reading, it is possible to have the factory values for 24v 35w resistance and for pt100 temperature probe in order to compare them with those I have, I tried to do the PID config, the values are different between hotend 1 and hotend 2 is normal? in addition, I find that if I set the same temperature between the two hotends, the filament has a different viscosity, let me explain better, I mold with the same filament, same brand, same color, hotend 1 and 2, from hotend 1 the filament comes out beautifully fluid as it should be, while in hotend 2 less fluid comes out, but the temperatures are identical according to the display, at the moment I don't have an infrared thermometer to be able to check the real temperature.
Edited by dadoblu_2000
- 2 weeks later...
On 1/17/2021 at 7:18 PM, dadoblu_2000 said:from hotend 1 the filament comes out beautifully fluid as it should be, while in hotend 2 less fluid comes out, but the temperatures are identical according to the display
Hi. Do you have identical feeders for nozzle 1 and 2? Did you check if the esteps for feeder 2 is correct?
Someone using DXU with Klipper?
Edited by tomazslapsak- 3 weeks later...
Getting Klipper to work with just the stock UM2+ is already quite the challenge. Making it work with this DXU upgrade would be challenging to say the least
- 1 month later...
qwerty8224 16
Thank you for the project yyh1002 2021 the system works and brings pleasure and joy)))))
- 3 weeks later...
qwerty8224 16
good afternoon firmware supports Linear Advance ?
- 1 month later...
Alexjx, could please share the Duet / DXU configuration files?
- 1 month later...
qwerty8224 16
knows who disappeared where Author yyh1002?
- 1 month later...
On 5/31/2021 at 10:35 AM, Garufa said:
file of the modified Head Bottom to keep the spring inside, working great for me ! hope it helps if interested.
- 4 weeks later...
Can someone help me get edited files for this to work on an ultimaker original? I feel like this to breathe a lot of life into my older machine, the problem is on the ultimaker original the rod entrance is different (the back and forward rod is on the top while left and right is on the bottom) on the ultimaker 2 its in reverse. I ve got no idea how to cad so help would be greatly appreciated as this seemed like a great option for the ultimaker original as far as dual extrusion goes.
I am more than happy to help getting any measurements.
1
- 4 weeks later...
On 7/22/2020 at 9:43 AM, alexjx said:I am.
Hello alexjx,
Can you please share your firmware editing and all the configuration file? Please.
Well be great if you can provide some guide how we can configure duet with DXU setting.
where does the PI Insulator goes? Can someone give me a photo showing that?
53
44
33
19
Popular Days
Apr 3
8
Feb 9
7
Feb 13
7
Sep 13
6
Garufa 53 posts
yyh1002 44 posts
ansonl 33 posts
LouDFPV 19 posts
Popular Days
Apr 3 2019
Feb 9 2024
Feb 13 2024
Sep 13 2020
Popular Posts
yyh1002
Hey guys, I would like to share a lever action dual extrusion solution I came up with for Ultimaker 2+. The approach is based on the great effort everyone put into Mark2 and Ultimaker
yyh1002
Some recent timelapse and photos of DXU.
yyh1002
Congrats on being the first to make it from overseas!(except for me;))
Posted Images
Garufa 11
Thank you for your design, I am trying a variation of it to keep the spring inside and not to reduce the cooling rings. please check the photos - if you modify the head bottom section to incorporate the spring adapter is even easier. let me know your comments. The drilling is easy and works great.
