zerspaner_gerd 383
2 minutes ago, gr5 said:works for me. Maybe video driver issue? Check windows update to see if there is an optional video driver update.
It is the talk of Cura Settings Guide Plugin.
OH WAIT! I have the same problem in the settings guide. Main cura is fine.
1 hour ago, SandervG said:
Thanks for notifying us. I'll forward it to the teams!
Luckily it's a plugin, so it can easily be updated by the plugin author (indeed some Cura team members in this case) and distributed through the Toolbox!
Selecting the new "Creality Ender 3" as printer from the list results in underextrusion. For reference I used exactly the same profile but this time I selected "Creality CR-10" and changed the settings to match the Ender 3 and it worked perfectly.
Is this a bug or did I just miss some settings?
Edited by cashy-
1
From the blog post:
QuoteWe’ve retired the ‘.curaproject’ extension. Project files now use a 3MF extension, for better compatibility between other 3D software applications.
There was never a ".curaproject" extension.There was a ".curaproject.3mf" double extension, but there's been a bug since forever on OSX where double extensions would become quadruple extensions. This has nothing to do with compatibility between other 3D software applications.
Who writes this, and why is it not checked by anyone who knows it is nonsense?
I have been using Cura 3.4.1 for two months. I installed 3.5.0 when prompted, but none of my profiles, materials or printer setup is in the new version.
I tried the backup/restore plug in. No Good.
I tried copying the definitions folder from 3.4.1 to 4.5.0. No Good.
Hey there, first of all: thanks for the great work!
BUT:
You disabled the ability to set the diameter in the sidebar. I now have to create a profile (wich is fine for me) but the profile doesn't seem to have any effect on the print settings at all. I tried to use the little "Fx" button to let Cura calculate the value but that doesn't do the job for temperatures or anything else i set in the material profile. As long as it doesn't use the diameter i set it into, this version is unusable for me (and for many many others cause it is a BIG difference to use the actual diameter wich is not always close to 1.75!...Yes...i don't have an Ultimaker like many many other users. I use the TronXY X5S and the Creality Ender 3 and nearly all the people in the FB groups use Cura too). Oh and by the way...It would be nice to actually show the color i set for the material in the drop down menu. Makes it easier to choose the right color when you have lots of profiles. ...keep up the good work and thanks for the Ender 3 profile in this new version (the filament diameter for the Ender 3 is not 2,85mm btw...not problem for me but people like Cashy in one of the previous posts will have a hard time finding the issue ;) it needs to be 1.75mm) .......................keep up the good work!
11 hours ago, cashy said:Selecting the new "Creality Ender 3" as printer from the list results in underextrusion. For reference I used exactly the same profile but this time I selected "Creality CR-10" and changed the settings to match the Ender 3 and it worked perfectly.
The filament diameter for the Ender 3 is wrong by default in the Cura profile. Go to the machine settings for the Ender, choose the tab "Extruder 1" and change the setting for "Compatible filament diameter" from 2.85mm to 1.75mm.
I can't view anything but the name of the printer and the extruders materials in the 'Monitor' tab.
I can't see the 'stop' and 'pause' buttons (stop button never worked)
Is there another way to stop a print?
The printer is printing but for Cura there are no jobs running...same thing for the web monitor.
Dim3nsioneer 559
That's a Cura Connect bug. Should be fixed with the next firmware release.
My Cura 3.5 won't load any STL thats a little mor complex than a Cube.
I Attached the Log File and hope if anyone can help me. I can't slice now :(
My forum post and the blog are usually based on release notes from Jira tickets etc. What I understand is that by dropping the .curaproject extension, and replacing it by 3mf the project files are compatible with more 3D software applications, and it got rid of that bug.
4 hours ago, OttoRenner said:The filament diameter for the Ender 3 is wrong by default in the Cura profile. Go to the machine settings for the Ender, choose the tab "Extruder 1" and change the setting for "Compatible filament diameter" from 2.85mm to 1.75mm.
This has since been solved on the master branch and will make it's way into the next release of Cura.
3 hours ago, dextop said:I can't view anything but the name of the printer and the extruders materials in the 'Monitor' tab.
You can try a 'Cura Connect reset' which is available via the printer's settings menu.
11 hours ago, James777 said:I have been using Cura 3.4.1 for two months. I installed 3.5.0 when prompted, but none of my profiles, materials or printer setup is in the new version.
Can you share the logs? Cura is supposed to upgrade your old configs to the new version, so something must have gone wrong in that process.
2 hours ago, SandervG said:What I understand is that by dropping the .curaproject extension, and replacing it by 3mf the project files are compatible with more 3D software applications, and it got rid of that bug.
And what I am saying is that your understanding is wrong, and I would suggest (again) that these texts are checked by engineers who pick out the crap. The original line, as it is in the Changelog is: " A 3MF extension is now used for project files. The ‘.curaproject’ extension is no longer used. ". The "better compatibility with 3d software applications" is just incorrect embellishment. There was an issue on OSX where Cura would create confusing filenames. That was fixed.
3 hours ago, ctbeke said:Can you share the logs? Cura is supposed to upgrade your old configs to the new version, so something must have gone wrong in that process.
Here is the log file for 3.5.0. The install did select my printer but only with the default setup. I had modified it including changing several things in the start and stop gcode and had a second modified version of the printer setup. I did start installing some plugins, but when I realized I would have to edit all the profiles, printer settings that I had tweeked etc, I stopped.
In the meantime I am still using 3.4.1, as it never uninstalled (or asked to uninstall) the previous version.
I see several errors:
- serial.serialutil.SerialException: could not open port 'COM5': PermissionError(13, 'Access is denied.', None, 5)
- cura.Machines.MaterialManager.__addMaterialMetadataIntoLookupTree [255]: Material custom_material_cartesio_0.4_mm contains a variant 0.4 mm that does not exist. It will not be added into the material lookup tree.
- UM.VersionUpgradeManager._getUpgradeTasks [278]: Config file [.\Monoprice+Select+Mini+V2+%28E3D%29_user.inst.cfg] is of version [4000005], which is different from the defined version [2000000], no upgrade task for it from type [user].
I've forwarded it to the developers as well (I'm currently not working on Cura).
Brulti 177
Same here.
