19 minutes ago, Daid said:It has a flow sensor, that works for jam detection as well. Yes, we spend a shitload of time developing this one. It has been in development even during the UM3 development. As we wanted in the UM3 initially, but we cut it from the release then when it didn't work properly. Solves the 750g spool problem. I think we've gone trough 2 different sensor chip designs, and a whole bunch of mechanical designs before that part was perfect. Then the software when trough a few large iterations as well. This was quite a ride.
Great! Looking forward to see what you came up with as I know that duet3d and prusa also haven't found the best solution to spot such yet.
May this also be available for the Ultimaker 3 series ?
22 minutes ago, Daid said:Grid based leveling. With the large build volume, our 3 point leveling no longer worked properly, as glass and aluminium plates are always a bit warped. (I think this will be backported to the UM3 as well, but don't hold me on that one)
So it's a completely new system internally? I would have thought that you are using the same olimex and just add the different protocols for the screen
nallath 1,123
My headcanon is that the S stands for sexy. So its the Ultimaker Sexy 5.
DidierKlein 729
Sounds like a boys band name![:p :p](//content.invisioncic.com/ultimake/emoticons/5a33abe3e5fc3_1f61bcopy.png)
kmanstudios 1,120
Better right than early!!
Squeal!!
Double Squeal!!
cjs 34
Great! I guess you are using new trinamic stepper drivers and maybe even a new 32 bit controller?
Haha
I first thought that someone at Ultimaker liked his Tesla Model S tooooo much ![;p ;p](//content.invisioncic.com/ultimake/emoticons/5a33abe4920ea_1f61ccopy.png)
