Hotfix 6.1.1 is on the way for the issue we've identified, pending tests and approval.
In some rare cases corrupted material profile files where giving problems and a small change in python's xml.etree.ElementTree library meant this caused the application not to start up.
As a workaround you can turn off Cura and "reset all printer settings" in the settings menu before upgrading, that will allow you to install the 6.1.0 without the current problem.
In the mean time if you have already gotten stuck at the logo screen, please open a support ticket as @SandervG said!
Use the 6.1.0 recovery image not a 5.x or older one! as mentioned a lot before 6.x can't be downgraded, this can brick your printer in a not user recoverable way.
- 3
jsw 19
I'm really glad I held off when the upgrade notice appeared on the front panel. I thought of this true-ism:
First rule of upgrades: Don't do it!
Second rule of upgrades: Don't do it just yet.
Even though I would like to have the static IP function, I'll wait until the 'stable' is truly stable later this year.
