1 hour ago, viola0083 said:Glad to know someone is still monitoring, however, I think the most efficient way is UM publish a new version, but in fact it’s older, hazard- free version, and most important of all, its updateed via USB.
just my 2 cents
best regards
100% agree with that, in fact there should always be an easy way to revert to previous version for just this sort of issue. I think having to dismantle the printer to get back to working software is a major failing in Ultimakers processes. Having said that many thanks to gr5 and the community in general for helping, but the manufacturer (especially of high end products like this) should not rely on community help
to get its users out of problems it created.
- 3
20
15
14
13
Popular Days
Mar 22
34
Mar 28
24
Mar 21
17
Mar 23
16
Smithy 20 posts
ScanHD 15 posts
kmanstudios 14 posts
itretail 13 posts
Popular Days
Mar 22 2019
Mar 28 2019
Mar 21 2019
Mar 23 2019
Popular Posts
SandervG
Hi everyone, Thank you for all the time and energy you invest in sharing your messages here, trying to share your perspective with others. I like to think that this all comes from the sa
Smithy
Since we only ever fill the threads with complaints and blames about bugs and errors, the positive should also be highlighted. Bringing the firmware from UM3 to the same code base was cert
nallath
There are 400+ people working for Ultimaker. There is no way that everyone can know what is happening at any given moment. So yeah, I do work for Ultimaker, but that doesn't mean that I can give answe
Posted Images
CarloK 204
The ER18 is an error for communication problems to the print head. Instead of re-attaching the cable, contact your reseller (as it says on our website ultimaker.com/ER18). Depending on production date of your printer there might be a permanent solution.
Regarding the SD-card slot, all our UM3 models have this. It is just a bit difficult to find. See the picture in GR5's article. You will have to remove the USB cable because the SD card connector is located underneath it.
