Post your latest print!
1/6 scale Darth Maul. Printed with PLA, 0.06 layer, 60mm speed.
Lightly sanded to remove support and 2 coats of primer, before second sanding
to remove seam line and artifacts.
The only appropriate word for this is WOW!
Absolutely stunning print... and he stands unaided too... well done!
Dim3nsioneer 557
Nice. It asks for more as you know:
Always two there are...
well I don't know this specie.... but it appears not to have the ability to procreate
Dim3nsioneer 557
Not exactly what I meant...
Haha..he's an eunuch and compensates with a LONG double lightsaber.
Plan is to dress and accessorize with garments made of actual fabric.
Not happy, so reprinting after tuning the UM, and doing a different pose.
Edited by Guestjangermann 12
Whoo, looks amazing!! How did you print it?
Care to turn it into a 3D Print upload?
That's a LOT of retractions! Nice work
Hi @Mechaneil, wow some very impressive prints coming from your side!
Did you model of them yourself?
What are you using them for?
Curious to see what they will look like after post processing. I am guessing you are also going to paint them?
Great work, please keep them coming!!
Dim3nsioneer 557
[print=4137][/print]
One of my latest prints: a Swiss Ultibot made on the Ultimaker 3.
- 4
Hi Sander, modelled it using DAZ3d and Zbrush. Head is a rework of this: https://sketchfab.com/models/6c7b7868399c4b7c85d9799823030cc7
And yes this will be painted and accessorized. First of my 1/6th scale SW SITH custom figures. Have Darth Talon and Assaj Ventress in the works already.
Edited by Guest- 1
flowalistik 181
[print=5422][/print]
- 3
That is amazing Flowalistik!
@mechaneil, how many parts did you split it up into? Looks fantastic.
Cut the model into 13 parts to get the best print bed orientation and minimize
overhangs, although minimal supports was still used, particularly in
the hands/fist area.
Edited by Guest[print=5422][/print]
Great to see the UM3's dual extrusion working very well.
Please post a print of something that is done with PVA supports.
Great prints being uploaded!!
I am jealous and need to swap my UM2 for a UM3! Part Ex anyone?
DidierKlein 729
[print=5434][/print]
- 1
zoev89 73
I just updated my design for the rain cover studs for my bike.
Hope they will hold a little better then the previous ones and that they damage the cover less.
viralata 78
Nice that the light comes through. Did you print it with a shell thickness of 1?
I noticed with some tests that the light passing through is not proportional to the thickness. More or less, up to 1.2mm (with the white blueish colorfabb) the light passes, with more thickness it's almost stopped. So the parts letting the light passing are here 0.8mm thick, the other ones 2mm thick.
